Old 02-26-2017, 08:12 PM   #1
s_nova69
70 c20 drum to 72 c20 disc steering linkage??s
I do know the outer tie rod is different. But the threaded end is a diff diameter too.
Will I need all steering component from a 72 c20 or will the 70 Putman and idler arm fit the 72 drag link??
Phil
'70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver
'72 short super build
4wd '72 Suburban LT4 coming soon!!
s_nova69 is offline   Reply With Quote
Old 02-26-2017, 08:15 PM   #2
davepl
davepl's Avatar
Re: 70 c20 drum to 72 c20 disc steering linkage??s
As far as I know, the ball joints are different so you need the upper and lower control arms. When I did this I used the center link, pitman arm (not sure if that's needed), control arms, tie rods and of course spindles.
Or did you manage to get the 72 ball joints installed into the 70 arms? Didn't know you could, but never tried.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-26-2017, 08:20 PM   #3
s_nova69
It looks like the idler and pitman are the same so just a different drag link and inner tie rids too. Geez.
Phil
