02-26-2017, 11:38 PM | #1 |
Wheel stud length with billet wheels
What length wheel studs are needed when running aftermarket billet wheels, say Raceline or Intro. Will stock length work?
Ive seen a few people here and there change studs, but never really saw a definitive answer. |
02-27-2017, 12:21 AM | #2 |
meowMEOWmeowMEOW
Re: Wheel stud length with billet wheels
It'll really depend on what wheel you end up with. The thickness of the flange itself will change depending on the center-section of the wheel. Steel wheels are usually thinner at the flange, so the amount of stud "in" the wheel will be different. If you look at mfg specs, many will list/give you the various dimensions of any stock wheel. Custom wheel mfg will usually ask these dimensions if your having something made.
Worth noting that if you do change studs, your lugs may need to be changed out as well. The capped acorn type nuts may not torque down all the way on longer studs, and if your a race-track type, then stud length is actually governable by NHRA rules.... BUT for the most part, if you buy a wheel thats set to fit GM Truck and full size car lug pattern, the stock studs should be alright. I've had various 5x5 wheels swap around, and on my 5x4.75 truck, I used all sorts of different wheels from GM vehicles (s10's, fbodies, random 90's stuff)
02-27-2017, 03:23 AM | #3 |
Diggin The SquareLife
I had stock ones
02-27-2017, 10:17 PM | #4 |
Ill stick with my stock ones and see if they work, thanks.
02-28-2017, 02:21 AM | #5 |
02-28-2017, 08:04 AM | #6 |
Many aftermarket wheels will spec a lug nut style. Lots of them use a lug with an extended shank.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
03-13-2017, 11:31 PM | #7 |
Post Whore
The NHRA rule on stud length is the diameter of the stud must protrude past the face of the lug nut seat. So if your running 7/16" studs you must have 7/16" or more stud sticking past the seat.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 03-13-2017 at 11:31 PM. Reason: -2 spelling |
