4.8 intake manifold vacuum port question
My 72 has a 2007 4.8 engine. There is a port on the passenger side of the intake manifold that is open and is sucking in air. When I plug it the engine rpms go down and the engine runs fine. This must have been for some sort of vacuum sensor or whatever. It's shown in the middle of this pic. Can someone clue me in to what it's for?? Thanks
1972 C10 Custom Deluxe 4.8 LS 4l60e |
Re: 4.8 intake manifold vacuum port question
I had the same vacuum port leaking on my 5.3 when I first swapped it. Idk what it originally was for, but I plugged it and it runs fine.
Yeah I plugged mine and it actually made it idle at a lower rpm which is fine. Just wondered what it was actually for....
I have never seen it hooked up to any oem vehicle I have looked at . I am sure there was a least one application for it . Reason is is leaking is because the tip was snapped off during handling . They all had a piece on the end to snap off if needed . I used mine for the vacuum supply for the heater and air controls in my 82 .
Homemade87,
Excellent info! Thanks a ton!
Its for the HVAC system in vans, they still used vacuum controlled blend doors during the GENIII engine times.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
That is what I use on my 78 for the blend doors vacuum source
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
