Old 02-27-2017, 11:45 PM   #1
weim55
Are 3 spd.stick column shift rods same for 6 vs V8 ??
Since the engine-trans is moved forward in a stock V8 application vs a 6 cylinder are the shifter rods that go from the column to the trans. different?
Possibly going from a six to small block in a '67 C10.
Thanks,
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 02-28-2017, 12:29 AM   #2
KyleSeal
KyleSeal's Avatar
Re: Are 3 spd.stick column shift rods same for 6 vs V8 ??
I cannot 100% say yes or no, but I do not believe they are different as the one mounting position that is changed are the front engine mounts, and for the Saginaw 3 Speed the only possible mounting for the bellhousing is in one place, which is fixed and cannot move. So my thinking tells me they would be the same.
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 02-28-2017, 12:55 AM   #3
weim55
The crossmember and bellhousing are both forward a few inches from a six application to a V8 so that moves the transmission forward as well. Thinking the rods might be a bit shorter?
