windshield install?
I've put a new windshield in my 69 c-10 with no problems before and the rubber around my 82 blazer looks like the same type of thing... so... has anyone put in their own windshield?
I ask because I can get a windshield for 30 bucks and if I have someone come and put one in it's 120! What do you think? |
for that extra $90, if something goes wrong, and it leaks, then you've got someone to ***** at and they'll fix it for free!
![]() beats having to do it again yourself, and risking breaking it. at which point your out the price of another windshield. |
Easy to do, I have done several in the past and they are a peice of cake. I dont know how the 69 is so I cant say its the same.
Chuck '85 Chevy Silverado 4X4 ![]() '91 Chevy 4X4 Suburban ![]() http://www.cardomain.com/memberpage/545941 |
Insert Witty Text Here
Around here a new windshield is about $125 installed. That would be worth every penny to me.
Slonaker |
Robert Olson Transport
![]() Join Date: Oct 2002
its the same basic principal for doin the windshield on a 69 and the 82 blazer, but like the others said, if ya aint a pro its worth the extra $$$ to let the shop assume the responsibility for setting it right and not damaging it. Windshields are one of the few things i wont mess with therye too easy to break and those cuts seem to go awful deep on the fingers
Thanks for everyone's input. I appreciate everyone's input but if it is the same as the one on my 69, then I am just going to try it out. I would rather pay 30 and try it... if it breaks or i hurt myself, then I will spend the 120 for someone else to do it.
I'll let you know how it goes! |
Windshield installing
Installing a windshield can be accomplished with some planning.....
Usually 2 guys are required. Removing the old windshield requires 2 guys with one guy inside and the other outside to catch glass as it is pushed out of the frame. After glass is removed all small pieces of glass must be gathered and the rubber washed in warm soapy water. A few tools are required. The most important aid is a squirt bottle with warm soapy dish washing soap.. A small plastic or nylon prying tool is a nise help to control rubber. The weatherstrip rubber is placed around glass, while a helper holds glass verticle on a work bench. Next, a piece of heavy twine or cord is wrapped around rubber starting at top of glass and ending at top. Small diameter white cotton clothes line cord works very well. Is is sometimes required to use some masking tape to hold rubber to glass on the bottom temporarily.. Place glass at window frame with bottom of glass resting on glass flange. Glass is gently but firmly pushed into opening starting at top. Inside man begins to slowly pull cord allowing rubber to overlap glass flange. This is a slow careful procedure. The loose end of cord mustbe held from being pulled out of rubber groove. With some care full pushing at bumping with plenty of soapy water on rubber the glass rubber will slide over flange. Careful inward pressure must be maintained or glass will slip out of flange and the procedure must all over again. Because glass becomes more brittle over time, used glass is the most difficult to reinstall successfully.......
Chevy stepper 400sb 350 turbo |
thanks frank,
I think the warm soapy water and string would be a great help. The last time i did it, i used a screwdriver and some wood shims. Thanks again. |
