02-27-2017, 10:54 PM | #1 |
Anti-Rattle strips under hood braces
There must be someone out there, that can tell me the specs. on the anti-rattle strips between the rear hood braces and hood on a 47-53 AD. How thick is it? how long is it?, and so forth. Appreciate it.
02-28-2017, 12:43 PM | #2 |
unbeleavable
I have posted 3 requests about the anti-rub material under the rear hood brace on the AD's. Are you telling me that no one with one of these trucks knows nothing about the material between the brace and the hood?. I would think that there was some restorers on this site that would have some input. Sorry for the rant.
02-28-2017, 01:10 PM | #3 |
Post Whore
Re: unbeleavable
02-28-2017, 01:40 PM | #4 |
Re: unbeleavable
I don't know anything about it but I can tell you for sure the way to get LOTS of positive responses is to post how impatient you are with members while you have a total of 12 posts.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
02-28-2017, 01:41 PM | #5 |
Re: unbeleavable
^^ what he said X 2
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
02-28-2017, 01:51 PM | #6 |
Re: unbeleavable
I saw your original post but didn't have a definitive answer because there isn't actually one. The anti vibration stuff looks to be tarred cardboard folded and slipped in where the metal doesn't fit tight with the cross piece. I ran my 48 without it since 1981 when I had the hood dipped and then louvered. In over 200,000 miles I have not noticed it vibrating but that doesn't mean it doesn't vibrate at times.
02-28-2017, 03:09 PM | #7 |
Re: unbeleavable
I think this is what you are referring to. I looked in my 47-54 Factory Assembly Manual and I could not find anything. So, I went and opened my hood. I don't know why it uploaded them sideways, but, the first picture is that stuff I think you are talking about. The second picture is taken of the hood further back. I cannot say this is the original stuff, it was there when I bought the truck in 1969. It looks like some type fiber material that was soaked in an oil substance.
If this is what you are referring to, I will try to get a better picture and measure it. Somebody help me turn the pictures back like they are supposed to be. Clay Attachment 1627492 Attachment 1627493 |
02-28-2017, 03:21 PM | #8 |
Re: unbeleavable
If this is what you are referring to, I will try to get a better picture and measure it. Somebody help me turn the pictures back like they are supposed to be. Clay Attachment 1627492 Attachment 1627493 Last edited by Clay54; 02-28-2017 at 03:25 PM. Reason: duplicate |
02-28-2017, 07:10 PM | #9 |
Thank You
A heart felt "Thanks" to those who answered my question about the anti-rub material under the hood braces. Thanks again.
02-28-2017, 09:58 PM | #10 |
Re: unbeleavable
3m used to make a two part expanding foam for just this. works great if you want results, if you want oe looks this is not for you
03-01-2017, 12:21 PM | #11 |
Re: unbeleavable
use neoprene foam in the thickness you need from Grainger if you want function. I have used it in the past and that is what LMC sells with their kits for the c10 trucks. 9 times out of 10 its not worth even messing with and looks ugly IMO. Also if you get too thick or use expanding foam it can deform the top of the hood. Another thing I have seen used that is somewhat more era correct is black roofing paper for smaller gaps or 3m strip caulk.
My '59 Build Thread |
03-01-2017, 12:55 PM | #12 | |
Re: unbeleavable
03-01-2017, 01:40 PM | #13 |
Re: unbeleavable
Hussey,
Well, you're defintely not wordy are you?! I had the exact same reaction when I first read it, but decided maybe a little sarcasm would work. I guess we made our point since there's been no response.
03-01-2017, 01:58 PM | #14 |
Re: unbeleavable
OP posted a new thread thanking those that helped...yes he did ... he has about 5 or 6 posts now all related to this very same topic. Obviously he needs to learn how to navigate a forum correctly while not stirring up folks...
03-01-2017, 02:46 PM | #15 |
Post Whore
Re: unbeleavable
Ill have to admit I had to bite my tounge when I first read this..here is the other...http://67-72chevytrucks.com/vboard/s...d.php?t=731549
03-01-2017, 02:51 PM | #16 |
Post Whore
Re: unbeleavable
Here's about the only reference to it in the manual..
03-01-2017, 03:36 PM | #17 |
Re: unbeleavable
I thought I had been on ever page of that assembly manual but must have missed that one.
03-01-2017, 04:44 PM | #18 |
Re: unbeleavable
So where can one find a copy of that assembly manual? Anyone know of copies floating out their on the web?
03-01-2017, 06:10 PM | #19 |
Re: Thank You
Just because you didn't get the answer you wanted, doesn't mean you have to be a d!ck about it. There are lots of great people, and tons of great information on this site...all for free.
And we are talking about vehicles that were built, mostly by hand, almost 70 years ago...when they used things like horse-hair, and cat-gut in the building process. Some of these cabs are half an inch or more out of dimension from side to side. It appears to me (after reading your multiple posts) that GM may have used this 'insulator' on some hoods and not others, where the hoods didn't meet the bracing well. There are a least a few vendors making damn never every part on these trucks. If you can't find it with them, I'd say, at this point, you're going to have to use some ingenuity. Now I'm being the a$$hole, but it's offputting that you would insult a group of people that have been a tremendous amount of help to me, because you're fustrated you can't find what you need. |
03-01-2017, 07:45 PM | #20 |
Re: unbeleavable
03-01-2017, 07:54 PM | #21 |
Post Whore
Re: unbeleavable
Assembly manual.http://www.ebay.com/itm/CHEVY-TRUCK-...JT6~Dl&vxp=mtr
03-01-2017, 10:43 PM | #22 |
Re: unbeleavable
[quote=Dan in Pasadena;7872504]I don't know anything about it but I can tell you for sure the way to get LOTS of positive responses is to post how impatient you are with members while you have a total of 12 posts.
Young man, I assume you're young, you need to remember, you can post a question and not get ANY advice or any response at all. This is all for free and entirely up to the readers to reply. You did get the attention of some of us, so you made your point, and you did get responses. Hope this brings to your attention in the future, post, relax and hope for the best. advice comes with experience and there's tons of that on this forum.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 Last edited by my56chevytruck; 03-01-2017 at 10:58 PM. Reason: a deep breath!! |
03-01-2017, 11:07 PM | #23 |
Re: Anti-Rattle strips under hood braces
Have you checked into the manual on this forum? Pull up the search link and put your items in question there. I can't help, but thats a great place to start at. Or Google it possibly.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
03-02-2017, 04:55 AM | #24 | |
Re: unbeleavable
https://www.amazon.com/REPAIR-SERVIC...ck+shop+manual to the OP *sigh* |
03-02-2017, 09:27 AM | #25 |
Re: unbeleavable
http://67-72chevytrucks.com/vboard/s...&postcount=104
Check out what alaska gasser did to his hood support. |
