Hauling my truck
I need to take my 68 swb truck to the paint shop and also to the muffler shop. Fixing to buy a car hauler probably (18 ft total - 16ft flat 2ft dove tail), but want to make sure that a 95 z71 single cab truck with a 350 motor will be suitable to pull the trailer plus weight of the truck. I'll have about a 200 mile round trip to make.
Roadtrip!
![]() Join Date: Feb 2003
Re: Hauling my truck
Should be no problem with that truck. Trailer brakes are nice to have. I just did 3100 miles in 8 days pulling this with my 94 1/2 ton with a 350.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Roadtrip!
Forgot the pic...
![]() Join Date: Oct 2015
I agree w too much stuff. Pulling should not be a problem...stopping could be a problem. Trailer brakes would help. I use my Z71 to pull car hauler w loads of hay and have towed my tractor as well.
I pulled mine home about 700 miles with my 02 z71 with a 5.3(327) with no problems. I definitely knew it was back there but we made it home with no problems
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
![]() Join Date: Jul 2015
Just load it properly with the right tongue weight and strap it down good. Your truck will pull it just fine, trailer brakes are a must on a car hauler, get a good controller. Its a night and day difference what a good, properly set up controller can do for you and your sanity.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
Pulled my 70 stepper from Knoxville to Cincinnati (300 miles) with my 2013 Chevy short bed with 4.8. Had no problem at all even thru mountains in Tn and south Ky.Trailer did have brakes and stabilizer bars.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
Shouldn't be a problem at all. My pulling truck is a 1993 k1500 suburban. I've put a lot of miles in pulling stock trailers fully loaded and hauled all sorts of trucks including my 1972 c20
1972 GMC C20 Custom Camper 350/TH350 |
most 18 ft trailers have 3500# axles, so 7000 gvw, you can subtract the weight of the trailer and what is left is the weight you can haul.....make sure it has electric brakes on atleast one axle, two is better....you should be fine with a trailer like that behind your truck...I have a 3/4 ton truck that I haul a 20 ft 12,000 gvw trailer with with no problem, has electric brakes....
