Old 02-28-2017, 11:19 PM   #1
coolfool_2
1961 Driveshaft to 1986 Rear End U Joint?
So i threw a 1986 rear end under my truck in the change over to 5 lug. Didnt realize the U Joints would be different sizes. Has anyone else ran into this issue and is there a wide to narrow U joint available to fix this issue? Any help appreciated. It seems the cups are both the same size but the newer rear end is wider(4 inches) compared to the 1961 driveshaft(3.5 inches)
Thanks,
Josh
coolfool_2 is offline   Reply With Quote
Old 03-01-2017, 07:45 AM   #2
PGSigns
PGSigns's Avatar
Re: 1961 Driveshaft to 1986 Rear End U Joint?
They make what we called off cross U-joinnts. Sounds like you need one to go from 1310 to 1330. This page has good information on both u joints and the sizes so you can verify what you need.
Jimmy
http://www.therangerstation.com/Maga...08/ujoints.htm
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-01-2017, 08:51 AM   #3
coolfool_2
Thank you, I did not stumble across this page in my research last night.
Josh
Old 03-01-2017, 12:03 PM   #4
53lowdown
Junior Member
53lowdown's Avatar
I found Denny's Driveshaft has good information on ujoints to adapt driveshaft to pinion yoke.
http://www.dennysdriveshaft.com/c130...oints_all.html
They were out of stock for what I needed, but got the part number, and ordered from Drivetrain America
https://www.drivetrainamerica.com/
_______________________________________
62 SWB BBW (under construction)
86 Vette Convertible
53lowdown is offline   Reply With Quote
