03-01-2017, 02:46 PM | #1 |
long distance towing questions with 1978 c30 3+3 dually
I posted this thread, and came to the conclusion that it was a bad idea with a half ton... http://67-72chevytrucks.com/vboard/s...86#post7866586
So I've run up on a 77 or 78 c30 camper special 3+3 dually 454, th400.. i can get it cheap, motor is seemingly sound, recent rebuild, for whatever reason, it has a torker intake (low rise single plane) that i will probably switch out for an older stock dual plane. I'm assuming it probably has 781 heads. I can get it cheap. Here's where I'm at. As explained in the thread, I'm moving from jackson ms to portland or.. i have to haul my kz1000 motocycle, tool box that's 700 lbs unloaded, random misc stuff, as well as my 69 swb c10 big block truck, on a u-haul trailer.. I've got a 2004 ram 1500 hemi quad cab, but there's no way i trust the dodge to go 2500 miles with that kind of load, especially being a high mile truck. I can also fix the old chevy on the side of the road, even if that means a Craigslist engine or trans. Provided the c30 is mechanically sound, would it be up for that kind of load and distance? It should be a 3.73 truck. Would 70 mph be out of the question? Im guessing in can expect around 8mpg? Shipp9ng my stuff is out of the question, and I'm getting the truck cheap enough, I'm pretty sure i could quick sell the truck and profit once I'm there. |
03-01-2017, 07:48 PM | #2 |
Re: long distance towing questions with 1978 c30 3+3 dually
If everything is in good shape on the truck it'll tow 5 tons as far as you care to take it. Not at a sustained 70 MPH, but 55-60 won't be flogging it. However, if it's not mechanically sound, getting itself down the road could be a challenge. The truck is rated for substantially more than the load you describe, but condition is everything - weight of the bike and toolbox both in the back of the truck isn't out of the question. The 454/TH400 is the best combo (at least as far as automatics go) they put in these trucks and 3.73's are a good gear for long hauls. 8 is a good, conservative number - I wouldn't expect any better than 10 from one in good, but used, condition.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
03-02-2017, 11:07 AM | #3 |
I have a 82 ,K-10 I bought new.
I put a 454/T-400 in it and it has 373 rears. I've pulled my 28" travel trailer all over the country with it. With my Honda 3-wheeler in the bed,along with a lot of tools in my gang box with a camper shell on the bed. It also has 33x12.5x 15 tires on it. Worst that ever happened was I burned out the trans in Hays,Kansas and had to replace the plastic governor gear a few times. Usually got around 8 miles to the gallon. I think you can do it with a one ton truck. Gonna have to dump the Dodge though! Mike. |
03-02-2017, 03:34 PM | #4 |
Like others have said, if everything is in good shape, that's an easy load for that truck. Years ago, I worked with a guy that had a 75 Chevy 3/4 ton with a 1 ton rear end, 454 mated to a 4 speed manual. Used it to haul his 5th wheel travel trailer all over the country. Often passed cars struggling up the mountain grades.
I wouldn't change the manifold since it might be there due to a non standard cam installed during the rebuild. Just use it and sell it once there. The less you spend the more you can profit. If you decide to keep it, then you can start changing things. |
03-06-2017, 01:11 PM | #5 |
As long as everything is sound you should be good, I moved from Houston Texas to dayton ohio with my 83 c30 and had zero problems, except for one tank working, so 8 had to stop for fuel every 120 miles
"DON'T TOUCH THE TRIM!!"-Early Kyler |
03-06-2017, 01:40 PM | #6 |
Whether or not 70mph is reasonable really depends on tire size... but it probably isn't. My C20 is 350/350/4.10/30.5" but I very rarely go that fast. If you do go that fast, 8mpg seems optimistic.
1973 C20, 350/350 |
03-06-2017, 02:16 PM | #7 |
The thing I would be most worried about is the brakes. People get all excited about what the truck can haul, but if you can't bring that load to a stop, especially in an emergency or on steep declines, all the towing capacity in the world won't do you any good at that point.
My advice would be to find a later model, early-mid 2000's 2500HD or 3500HD. They have newer, more reliable, engines, better transmissions, Overdrive, all the extra coolers built in, hydroboost brakes, and 4 wheel discs. Not to mention better mileage (I average 11 mpg with my 6.0L when towing, with an 18' steel trailer, bed full of tools/equipment, and a full size truck on the trailer), and a more comfortable vehicle overall for a long haul, especially with A/C! |
03-06-2017, 02:22 PM | #8 | |
03-06-2017, 07:03 PM | #9 | |
Even so, the heavier duty square body brakes are good. My recollection is that my C20 has bigger rotors than a 2500HD of the era you speak of (not by much, but a little). Obviously no ABS though.
1973 C20, 350/350 |
03-07-2017, 08:42 AM | #10 |
There is no replacement for displacement so 454 engine wins big time over the 6.0 in the newer 2500 HD's.
03-07-2017, 09:18 AM | #11 |
Carbureted 454's suck an unbelievable amount of fuel, without an overdrive, and 70 MPH. OMG! Maybe 4 MPG.
IMO , not sure how long that motor will last cruising it at 3000+ RPM.
Desert |
03-07-2017, 10:43 AM | #12 | |
my fuelie 454 crew can manage 'bout 5-6 mpg's empty, 3 or 4 when towing with the camper....but it does run all day long at 3200 at about 55-ish.... (4:56's) |
03-07-2017, 12:07 PM | #13 |
I'm about to be in the same boat.. kinda.. bought a c30 454/400 to tow my boat.. trying to decide to take it on the long trips this summer.. first trip is 11 hours and 650 miles each way towing 7k boat.. month of June will have 2500 towing miles
3:73 gear truck, thinking if I can get some 285 tires under it I'll do that to help with rpms.. if I could run 65 comfortably all day I'd be happy.. just used to running 80 with the dmax lol.
61 apache |
03-07-2017, 12:15 PM | #14 | ||
This is some pretty old school thinking...today it's more about engine efficientcy than it is about simply cubic inches. I've towed with both and I can tell you that I was less than impressed with the 454, new tech is where it's at. That '78 454 was rated somewhere about 240hp/370lb•ft, when it was new. Even the older 6.0L was rated at 300hp/360lb•ft, at nearly a 100 cubic inch disadvantage. Some of the later ones got bumped to 361hp/385lb•ft! The 454 does have a longer stroke, but that's about the only advantage you'll find with that engine. The 6.0L is lighter, more efficient (better mileage/more hp per cubic inch), won't overheat on long climbs, fuel injected, backed by overdrive, and will outlast a 454 by a long shot. To me, guys that are stuck on 454s are there for the badge. Modern tech has left these engines in the past. Sure, they can make reasonably cheap power, but when there are many better options out there today, take advantage of the technology available! |
03-07-2017, 03:20 PM | #15 |
The 454 makes more torque at lower rpm, while the 6.0 makes the torque at higher rpm. I've certainly seen people claim that, comparing a 454 truck to the 6.0, the 454 tows better. Don't know if it's true.
1973 C20, 350/350 |
03-07-2017, 04:17 PM | #16 |
They are thirsty but the very worst mine's ever gotten was 9.5, towing a 9,000 lb. trailer 450 miles at 60-65. And they will last.
03-07-2017, 04:24 PM | #17 |
4.10's with 30.5" tires is on the short side. My '85 with 32 inchers and 4.10 is right in the sweet spot at 60, doesn't protest at 65, but you can tell everything's spinning good and fast at 70+. 3.73's put a truck with 32" tires at 2,800 @ 70, which if you look at factory literature for the mid 80's truck 454, is right at its torque peak.
03-07-2017, 04:57 PM | #18 | |
61 apache |
03-07-2017, 08:08 PM | #19 | |
I ran mine with 33's all over the country(including Canada!) It did very well on the interstate,but was pretty sluggish in the mountains. The 454's low end torque(and,low gear) was the only thing that saved me on the hills. Mike. |
03-08-2017, 08:31 AM | #20 | ||||
Desert |
03-08-2017, 10:17 AM | #21 | |
edelbrock cam and fuel injection, T400 with 4:56's = glug, glug, glug... |
03-08-2017, 11:54 AM | #22 |
What the ?? My CC Dually gets 10-11 empty and I can pull 9 towing if I keep it 60-65.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
03-08-2017, 12:25 PM | #23 |
OE 454 that's .030 over w/flat tops
rebuilt stock 'peanut-port' heads RV/towing grind cam Edelbrock TBI intake + spec'd ECU chip th400 w/shift kit 1 3/4" full length headers, true duals w/H pipe heated o2 sensor mechanical fan w/HD clutch 4.10's & 31.5" rear tires (235/85-16's) 9mpg on a good day @ ~3k rpm/65mph.
03-08-2017, 12:27 PM | #24 |
It seems like the 454 keeps getting knocked. The 6.0 is a very good engine, no doubt about it! But the 454 has been around for a long time and mine has happily accepted anything I could throw at it and keep coming back for more! I've towed plenty up the Altamont Pass, at 65, with plenty more on reserve if I wanted. My truck has 4.56's, 35 inch tires, and a 465. Mileage was about 8mpg towing. My buddy sold his 02 2500 with a 6.0 because he hated the 10 or so mpg around town empty.
As long as the truck the OP is looking at is mechanically sound, and brakes are good, he should go for it! |
03-08-2017, 01:00 PM | #25 |
Sounds like my 10mpg expectation wasn't unrealistic.
Time for a tune up and the long tubes to get installed.
61 apache |
