Protecting Rockers and Corners?
So my truck is in need of new rockers, and cab corners. I am not sure if I want to tackle this myself or have a professional tackle it. My concern is even after I get the old rust out, how can I prevent new rust from forming?
Any tips or tricks to prevent the issue from being an issue when my grand son gets his grandpas old truck?
Confidence is the feeling we have before we fully comprehend the situation |
Re: Protecting Rockers and Corners?
Im fairly amateur and I was able to do it, cab corners are cheap so if your unsure of yourself grab 2 of each :-) With the rockers, I use self tapping screws to hold into place then test the door, remember when you remove the rockers the door jam will move, you can cross brace as well, im sure thats what the pro's do ;-)
When done, you can use a stone guard, it's a clear spray that will leave a slight texture look, but will protect them, make sure to inspect your inner rockers as well, you may want to just do both while your there. When all's done and said, Im actually thinking of using spray foam inside to keep the moisture out :-) |
#3 | |||
"I ain't nobody, dork."
I used "Rust Mort" spray on all of the exposed rusted parts before doing any welding or primer. It turns rust to iron oxide. Worked really well. I wouldn't use any kind of spray foam as it will hold moisture at the metal. Here is a couple pics of my floor cut out and everything lined back up just fine... Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
X2 on Rust Mort. Also, the rockers rust from the inside out. in the front there are inspection plugs (plastic 1" plugs) after installing the new rockers, spray the inside through these holes with cavity wax (body schutz, sp?) This applies a protective coating that will prevent rusting.
#5 | |
Post Whore
![]() Join Date: Feb 2016
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
ahh good to know, as i said, i prefaced my res ponce with im an amateur lol
when i got my truck it had the outter rocker and cab corner rivited on .. when i removed it I had this to look at, needless to say, the door did not close when i removed them, I used a come along and the set tapping screws to her it to hold together correctly for me to put the inner and outters back on :-) and I had to remove a HUGE part of the floor LOL |
#7 | ||
In your case... I might add a couple braces... Wow!
Gary
All about them K’s
![]() Join Date: Jun 2014
That's where mine was at except I didn't have to do the front lower pillar tips. I didn't brace anything. I left the doors on and and made Sure I could get them closed, and had nice gaps. From there I just clamped it all in place best I could and tacked it up a little at a time checking very frequently that nothing moved.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#10 | |
Post Whore
I am convinced the solution to the rocker problem is to make them easy to replace--unplug, remove, insert, plug in--and just go through the process every other year.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
#13 |
Post Whore
That's the ticket. Make some inner rockers out of 1/4" flat bar and add some neo magnets to hold the outer rockers in place. Take them off once a year to repaint. You're a genius!
#14 |
my advise/opinion; being a 3rd generation body tech/painter, and spending half my life in this salty environment, I've seen, fixed alot of rusty vehicle, and tried my best at preventing rust from destroying all my hard work. A sort-of fix mt father taught me and his pa taught him is to drill small holes along the lowest points of the body that typically rusts. Do this pre-paint if possible. keeping the holes small as possible but able to get small straws up inside and swivel around a bit. then there are two ways to close it up and still use it in the future. 1) is to buy very small rubber plugs with a outside lip i.e. 1/8", 7ish mm. I find the best place to get these is in bulk from Ebay, they are cheap and disposable, around $5-10 per 100, 2) is to use 1/4" stainless auto trim screws and get some very small rubber washers, also i get in bulk from Ebay. Fora rust preventative, there is a aerosol spray can sold by all auto paint suppliers (varies in manufacturer and name but same chemical inside) that is used to spray the backsides of auto panels that don't get painted, it is a little pricey but not out of this world expensive, and you just spray it through the little straw, inserted in the drilled hole all around inside the area on the vehicle then plug it off. repeat every couple years or so depending on how salty your region is. My father substitutes the fancy spray chemical with plain old spray Carnuba wax, or the dry silicone spray that's used by welders and metal and pipe worker, don't know the names of it but it's very commonly used in those field of work. It's used for bare metals to prevent rust while their project is under construction. Its also pre-coated on most raw metals sold for fabrications, the stuff you have to wipe off with laquer thinner or other chemical before welding or prepping for paint. Any major Welder should know of it and what its called. Again use as needed pending your region. I recommend also that if you drill your holes into the panels that are already painted, wipe a little bit of seam sealer, like used on driprails around the hole itself. Allow it to dry before putting the plug or screw in the hole though, it will prevent future headaches. Hope this helps a few of ya's out. any questions, just ask n I'll help out the best i can
72 C/10, LWB, 5.7, Auto, with A/C ![]() F.B.I = Full Blood Indian Appalachia/Eastern Cherokee,"Tsalagi" |
