03-01-2017, 03:22 PM | #1 |
New Resr Springs Too Wide for Hanger
I have a 1949 3100 and recently purchased new rear lowering springs. I tried to install them but the spring is too wide for the hanger. The old spring measures about 1.69" the new one is 1.72-1.74". Has anyone had this same problem and what was done to fix it? Thanks Russ
03-01-2017, 03:32 PM | #2 |
Re: New Resr Springs Too Wide for Hanger
It was always my understanding that stock springs were 1.750 or 1-3/4 inches.
I think on the front of my truck I had to take a bit off the inside of the hanger or "smooth it out' when I put it together because the hangers were slightly collapsed due to possible over tightening at some time. On yours it shouldn't take much work with a flat file, flap wheel or grinder to take a couple thousandths off to get it to clear. Even with the bolt/pin tight in the hanger the spring should swing up and down on the bolt easily as you don't want it to bind up.
03-02-2017, 06:04 AM | #3 |
