Old 03-01-2017, 03:27 PM   #1
sharkskinman
Dual drum MC adapters
Og MC..7/16-24
New MC 1/2-20 front..9/16-18 rear
Front wheel cylinders are 7/16-20
Rear are 3/8-24...
Rear rubber hose is 7/16-20 male..3/8-24 female
I'm using existing line to the front T
and running new to rear line ..
What adapters do I need for the New MC to existing front line?
Plug for T?
For new rear line to existing rear line??
Haven't found definitive answers
sharkskinman is offline   Reply With Quote
Old 03-01-2017, 10:42 PM   #2
blown240
blown240's Avatar
Re: Dual drum MC adapters
I don't know the exact numbers, but if it helps I can get some pics of mine tomorrow.... I did a dual circuit, power, drum drum conversion a couple years ago.
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 03-02-2017, 04:39 PM   #3
sharkskinman
It's from info on a couple parts websites..
3/16= 3/8-24?
1/4= 7/16-24?
What is the Tee?
Old 03-02-2017, 04:57 PM   #4
scoot_mcgrute
I've found that it depends on the year you are working on. I know my 66 had factory 1/4" brake lines but the earlier trucks were 3/16" brake lines.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 03-03-2017, 08:06 AM   #5
PGSigns
PGSigns's Avatar
You need a 1/4" plug to in the tee where you pull the line to the rear out of. Then a 1/4" coupler to join the new line coming from the master for the rear brakes. Then take the master cylinder you have to the parts store and tell them you need to go to 1/4" lines from what you have and they will get you the fittings. Use the new nickle copper lines when you get your parts. So much easier to work with.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-30-2017, 01:27 AM   #6
sharkskinman
Did complete front brakes today (rear cylinder bolts messed up)
And put in a dual drum MC
Got one from a 67 C10..
Bolted right up (my 65 Does have an adjustable rod) but didn't have to touch it
1/2-20 male to 7/16-24 (1/4 line to front) adapter for front port
9/16-18 male to 3/8-24 (3/16 line to rear) for rear port
1/4 plug and 1/4 union
I had front port to rear and vice versa but was getting flow from front first and front wheels (back port) weren't bleeding..
Went got another adapter and put front port to front wheels and rear to rear
Bled quite a bit
A Lil spongy still but Way better than before
Old 03-31-2017, 12:13 AM   #7
Captainfab
60-66 Nut
With the '67-'70 truck master cylinders, the front port is front brakes and rear port is rear brakes.
