03-01-2017, 11:34 PM | #1 |
Original air cleaner on new Holley carb
Anyone running an original air cleaner and quadrajet spacer on a new Holley 4bbl carb? Should it fit? Wanting to put one on a street avenger 4bbl Holley.
03-02-2017, 12:18 AM | #2 |
Moderator
Re: Original air cleaner on new Holley carb
I know it will fit on a Carter/Edelbrock, should fit a Holley with no problem either.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
03-02-2017, 12:41 AM | #3 |
I am using the original riser with the breather tube but with an aftermarket air cleaner and a Street Avenger carb. I did have to modify the riser because one of the Holley butterfly shafts was contacting the riser and binding. I can post a couple pictures of the modification if you are interested.
03-02-2017, 07:12 AM | #4 |
Thanks to both for a quick response. I'd definetly be interested in some pictures of the riser mods.
03-02-2017, 10:44 AM | #5 |
Subbed for info!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
03-02-2017, 02:21 PM | #6 | |
Picture #1: Mark the locations (after I took this picture, I realized I needed to rotate the riser 180 degrees so the hose from the rear of the right valve cover would enter at the correct location). Picture #2: Shape one end of the pipe to match the curvature of the riser. Picture #3: Place the ballpein hammer, rounded end up, in the vise. Picture #4: Place the riser over the hammer in the vise so it contacts the marks where the rod binds. It may help to have someone hold it in place. Picture #5: Place the piece of pipe on the riser above the ballpein hammer and hit it with the other hammer until you have created enough clearance for the carb rod. |
03-02-2017, 02:22 PM | #7 |
Last picture.
03-02-2017, 08:41 PM | #8 |
This is excellent! Thanks for the detailed pictures and instructions
