Front end swap help
I got the entire front end off of a 1985 GMC c10. Like, everything. Literally unbolted from the frame and got everything including steering stuff and brake master cylinder and brake booster. I have a 68 c10 that I am putting a 5.3 and 4l60e in, so I needed to do a front disk swap. I got the front end pretty much figured out, but what about the power booster? Do I need to drill new holes? What about my pedal? Thanks for your help. Also, I'm wanting to add a sway bar here soon, would I need to order a sway bar for the 85, or can I order one for 68?
Re: Front end swap help
Looks like you asked for help on this over a year ago. Just wondering if you got finished? I'm planning on doing the same thing before long and was just searching around on here looking for help.
Use a booster for you year truck.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
![]() ![]() Join Date: Sep 2008
Wow I can't believe nobody piped in on this last year.
Use a booster from a 67-72. The sway bar should be the same for all through 87. Diameters may vary. The power steering fittings will be metric o-ring. It's a pretty straightforward swap.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
Me either. He hasn't been back since 3/13/17.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
