Old 03-02-2017, 05:17 PM   #1
72tutone
XJ Intermediate Shaft
Ive been all over the boards, combed through google pages and yet to have found a clear cut answer.
Can you install an XJ Jeep Intermediate Shaft on a 67-72 C10? It seems everything I have found is all for the squarebody 73-87 guys.
Can this be done? Same setup as before? 84-96 XJ Jeep, notch on the shaft to clear the bolt? Is the spring still necessary on the shaft?
72tutone is offline   Reply With Quote
Old 03-02-2017, 09:48 PM   #2
72tutone
Re: XJ Intermediate Shaft
No one knows?
Old 03-02-2017, 10:04 PM   #3
ratty69
I researched it a bit myself, and it seems to work only on 79+ vehicles with the double D shaped steering shaft in the column.
This link shows it well, scroll through it:
http://www.chevyk5blazer.com/forums/...aft-conversion
Our trucks use a splined shaft in the column, so no go. I've been hoping to find a 79-83 square body column for cheap, and try swapping the shaft into my 69 column in order to get the double D shaft. So far no luck on the donor column, so don't know if it'll work.
Hope this helps.
ratty69 is offline   Reply With Quote
Old 03-02-2017, 10:24 PM   #4
72tutone
Thanks for the info. I found a user on the board blazerman who says he put it on his 67 -72 model trucks. So now im even more confused lol. But he doesnt have a pic of the install. So im at a loss now
Old 03-02-2017, 10:39 PM   #5
ratty69
I know the post you're referring to. It's what I call a teaser thread - it tells you something's possible, but not HOW. There are a couple of those on here on various subjects.
Old 03-02-2017, 10:55 PM   #6
v30crewcab
v30crewcab's Avatar
I just put one on a 66 suburban but I had to put a new joint on the top end to mate up to the steering column. wasn't really cheap at that point but it worked.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 03-02-2017, 10:59 PM   #7
72tutone
Well, i guess i will just have to stick with rebuilding the rag joint. If it was as easy as the 73-87 guys it would be a no brainer
Old 03-03-2017, 12:39 AM   #8
Robznob11
Robznob11's Avatar
grand cherokee steering shaft install - The 1947 - Present Chevrolet & GMC Truck Message Board Network
http://67-72chevytrucks.com/vboard/s...d.php?t=593096
Here you go. If it means anything to you I am swapping to a powersteering gear box tomorrow and I alread tried the shaft on the box and it seems to fit fine. Yes it blows my mind caus everything i research says manual is 3/4 x 36 and power is 3/4 x 30 .
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 03-03-2017, 12:41 AM   #9
Robznob11
Robznob11's Avatar
The ps box i have is a 84 tho....
LED TAILS
Old 03-03-2017, 04:11 AM   #10
James the III
Another option is the astro van.. iirc.. the one on my SS is 2 pieces so the frame to body movement doesn't bind the box or column and kill bearings/etc.. like the solid shaft will.
on the jeep it doesn't matter as it's unit body...
THe astro has a bolt in subframe on rubber bushings.
James the III is offline   Reply With Quote
Old 03-03-2017, 09:08 AM   #11
72tutone
What year should I be looking for? I'm heading to the JYD this weekend.
Old 03-03-2017, 09:22 AM   #12
James the III
All the same.. rwd not sure if the awd is the same.
