trans ?
Can someone tell me what type trans this is?
pic2
pic2
ttt
69 swb stepside, rebuild and upgrade in progress |
Recovering Truck Driver
saginaw 3 speed
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
Yeh It's Fast
Thanks always wondered that myself ,i have the same
![]() ![]() ![]() ![]() Click here to view pictures of my truck ![]() ![]() ![]() ![]() Zwijndrecht, The Netherlands Europe |
Buck,
What else was there for a 3-speed? BW? What's the telltale quick glance trick to identifying a Saginaw? |
What gives it away to me is the shift shafts in the side of the trans and the plates on the side (not toploader)......I've spent a few hours swapping them around in my convertible)...I'm told there was a toploader 3spd (same one f#rd uses) that was also used in 60's and 70's GM products, but I've never seen one, I don't know if mucie made it or rockwell or who?
Fabricate till you "puke"
I have seen the old toploaders that were in some of the Olds & Buicks......its been a while, but I think they were a Tremec trans. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
