Old 03-04-2017, 10:19 PM   #1
Marcus4800
Drum Brake Question
I know this may be a dumb question but I'm installing new brake shoes on my 63 C10 Stepside. So I bought the shoes for the front and the back (they are the same) and I bought 1 universal spring kit front and 1 universal kit for the back. I assumed one kit would do both front and the same for the back. After spending 4 hours trying to get one of the front ones on and thinking the springs are color coded I realized that the kit only does one side (I think). The other springs would not come close to lining up. Looking at the springs I took off and the way I have them installed matches. In short does 1 universal kit just do one brake drum?????
Thanks in advance Marcus....
Marcus4800 is offline   Reply With Quote
Old 03-05-2017, 12:04 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Drum Brake Question
One kit should do both sides but not all four. You would need a one kit for the rear and one for the front and they might be different.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 03-05-2017, 12:17 PM   #3
Wrenchbender Ret
63 was the first year for self adj. brakes. If yours does not have self adjusting brakes you need a corresponding kit. The kit covers both sides of one axle. On self adj. brakes one return spring is shorter than the other.
Wrenchbender Ret is offline   Reply With Quote
Old 03-05-2017, 12:32 PM   #4
Marcus4800
Thanks for the help. Mine does not have self adjusting brakes. The springs I took off were all the same length so I had to use the two long ones to make it work. Which means I'll have to buy a kit for each wheel....
Old 03-06-2017, 05:25 PM   #5
Wrenchbender Ret
Buy a kit for a 62 model. The adjustment rod spring will be different also. Some of the holdown parts will also be different.
