03-04-2017, 11:07 PM | #1 |
84 c20 5.3 sm465
Just figured I would post this swap I did for my friend. We Put a rebuilt 5.3 with cam and valve train upgrade in a c20 with factory z bar sm465 transmission. Took about 2.5 days so far. Pulled old motor last Saturday and installed the new motor and trans the same day. Finished 90% of the wiring that Sunday. Finished the rest today and finished the fuel system. Flushed the lines and started the motor for the first time. Started right up. All that's left is egr block off plates for the vett manifolds and test drive. Very happy with the outcome.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
03-04-2017, 11:11 PM | #2 |
Re: 84 c20 5.3 sm465
More sorry for them being sideways. I can't seem to fix them
03-04-2017, 11:18 PM | #3 |
For anyone interested corvette manifolds off of a 04 supposedly z06 work fine with the z bar with dirty dingo truck engine mounts. Keeps the engine in the same exact spot as it used to. We reused his factory sm465 bellhousing and and advanced adapters flywheel/clutch set up. He chose to use the upgraded center force clutch over a factory replacement clutch. This motor should be pretty close to 400 HP at the flywheel. Tsp cam, flat top pistons, trunnion upgrade and compleat rebuild .020 over. I can't wait until he gets the exhaust finished Monday.
03-05-2017, 09:11 PM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
Nice!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-05-2017, 09:33 PM | #5 |
Post Whore
Yep he's gonna like that engine..I had the sm465 but changed to a nv4500 for the overdrive...I'm well pleased
