Old 03-05-2017, 01:44 AM   #1
AB6DO
Headlight bucket repair
One of the head light buckets from my 1948 3100 has the tab that holds the chrome headlight ring mounting screw is missing. Looking for repair suggestions.
AB6DO is offline   Reply With Quote
Old 03-05-2017, 09:22 AM   #2
DransportGarage
DransportGarage's Avatar
Re: Headlight bucket repair
I've never had much luck repairing those. The good news is, they're stainless and never deteriorate unless they get run over, so they're around. Get a good used one.
One additional tip: Don't try to polish them on a buffing wheel unless you don't need your fingers or other body parts. Ask me how I know...
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 03-05-2017, 02:41 PM   #3
OrrieG
OrrieG's Avatar
Ditto, face mask saved my cheek, but sliced my finger good...
OrrieG is offline   Reply With Quote
Old 03-05-2017, 03:39 PM   #4
Donaldo
I think he's referring to the tab inside the bucket, not the stainless outer ring.
since you are in Fresno, I'd check with Turners out on Willow. Maybe have a replacement bucket.
Or if you have a some metal a drill and a welder, fab one yourself.
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 03-05-2017, 09:30 PM   #5
mr48chev
mr48chev's Avatar
Gotta read the whole question all the way through before throwing out an Answer.
I've got a couple of smashed headlight buckets on some fenders but I don't know if that bracket is usable or even there.
What I would do is cut a new bracket out of sheet metal and shape it to fit and tack it in place but use one of those tin clip nuts that you can get out of the little slide boxes above the bolt bins at Ace to screw the hold down screw in. Drill the hole a little bigger and slip the clip in place. Make the piece match the one on the other side.
My ongoing truck projects:
Old 03-05-2017, 09:47 PM   #6
DransportGarage
Sorry. I was off on that one. I saw "stainless" and went for it. That said, if I feel like throwing out an answer...
Bob
