carb/hei ???
I have recently put on a Edelbrock performer intake with a Holley 1850 carb. I have set my timing to 10 degrees bdtc and carb idle at 750 rpm. Book shows 4 degrees bdtc but I believe this is with points. I have tweaked the idle mixture screws and I have about 27 inches of mercury on vaccuum gauge. Is there anything else or any changes that I should make to the above to pass an emissions test. I failed miserably with the original intake and quadrajet. I have 2 more chances before the end of October to pass. Any help or advise would be greatly appreciated.
CCRider
With the Holley it is really easy to adjust the float...I would lower the float till it would barely run. This should lean out the mixture quite a bit. Limp up to the inspection station, pass the test, and come back home and set the float where it was.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
#3 | |
Glowing since 1978
I can honestly say that I have never seen a car engine that would do this. You must have no overlap to draw that kind of vacuum.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
I agree with the emissions bull sh!T, here in Ontario it is even worse! You can drive anything if you safty it and purchase a $15 permit every 10 days to by pass the e test? What a joke!
I drove for two years with trip permits, and this thing layed out more black smoke then a freight train! The good thing is the e test is only on vehicles 20 years and older, which protects my truck! After 20 you can pump out purple smoke! What a joke! The sh!t head Ernie Eves and mike Harris should go spoon in the woods. At least there they would be productive! This whole bs story is all about the government tring to weed out the gasoline engine, which they fd up in the first place! You sell something YOU should be responsible for it not the consumer! $0.02!! ![]() ![]() ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
