Old 03-05-2017, 12:55 PM   #1
lux
RideTech air springs and AntiSway bar
Ive installed Ridetech's RidePro digital 4 way system on my 72 C10. I also have CPP tubular control arms. Is any one using or recommend using an antisway bar on the front end?
I want the better handling in the corners but I'm afraid the antisway bar isn't designed to move in the up and down range of an air bag system.
Also I was hoping for the added benefit of no tire rub when going up driveways at an angel. I have very little of that now at ride hight but it does squeak just a little.
lux is offline   Reply With Quote
Old 03-05-2017, 11:06 PM   #2
youngrodder
youngrodder's Avatar
Re: RideTech air springs and AntiSway bar
I use antisway bars front and back on my 48 truck. I also went with ride tech (4 way system). They will help to improve the overall ride. On my 53 suburban that uses a Porterbuilt drop member I'm using a front antisway bar on that.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 03-06-2017, 05:33 AM   #3
lux
Thanks for the reply, I really only ever drive it at the ride hight setting so it makes sense that the antisway bar would work well if set up to that hight. I'm sure I'd also need to make sure it doesn't bind or rub the bags at any other bag hight. I think the CPP bar for the tubular control arms attaches well away from the bags.
I'm interested how you used a front bar on the rear of your suburban. I'd like to put a bar on the rear of my truck but, I put my pumps and valves in the spot where it would attach to the frame.
Old 03-06-2017, 11:43 AM   #4
JohnJ@RideTech
JohnJ@RideTech's Avatar
Sorry for the slow response.
Check out the link below to the sway bar that we recommend for your truck. This bar will work just fine for your suspension. Check it out and let me know what you think.
http://www.ridetech.com/store/1963-1...musclebar.html
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 03-06-2017, 01:31 PM   #5
lux
Thank JohnJ, can you tell me the measurement from mount to mount on the control arms? I'd like to measure that against my mount holes on the CPP tubular arms.
Also I'm incredibly happy with the RidePro system.
Old 03-06-2017, 04:19 PM   #6
jweb
jweb's Avatar
The No limit rear sway bar is nice, not sure if it will work with your setup. It fits above the frame which is nice for ground clearance.
http://www.nolimitengineering.com/pr...tegory=6157532
jweb is offline   Reply With Quote
Old 03-07-2017, 09:17 AM   #7
JohnJ@RideTech
The sway bars are right at 45 1/4 inches from center of end link mount to the other. I hope that helps you out a little bit.
Glad to hear you like the RidePro system. If you ever need anything or have any questions, feel free to contact me directly. ill be more than happy to help you out.
John J.
Sales/Tech
