Old 03-05-2017, 03:53 PM   #1
blazer2007
need new steering shaft opinions and suggestions
I,m replace my steering column on my 78 2 wheel blazer and I need the D shape steering shaft.Should I change to a u joint style while I,m here or replace the rag joint. Is the u joint style that much better ? If I change to a u joint setup what is the best options.I see a jeep swap on u-tube but not sure if this is a proper way to do this.thanks
blazer2007 is offline   Reply With Quote
Old 03-05-2017, 07:56 PM   #2
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: need new steering shaft opinions and suggestions
I changed over to the Jeep shaft. I can't really say that it's better than a new rag joint would be, but it's certainly better than a 30 year old rag joint for sure. And pretty easy as well.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 03-05-2017, 08:53 PM   #3
lilpoindexter
lilpoindexter's Avatar
I used a HELP! rag joint from Autozone when I swapped in my powersteering box. Steering is TIGHT. I think there is a big rag joint and a small one. In fact the tight steering is one of the great things about my old beater truck.
lilpoindexter is offline   Reply With Quote
