Old 03-05-2017, 05:50 PM   #1
macdodd127
door tension
I have a '69 C10 fleet. The doors close WAY to easy. Won't stay open if on any kind of a grade. I notice there's a double piece of metal(tensioner) I believe. If thats the what controls the closing tension, can I spread it apart to tighten the door up?
macdodd127 is offline   Reply With Quote
Old 03-05-2017, 08:34 PM   #2
berch 69GMC
berch 69GMC's Avatar
Re: door tension
It should have a type of shims between that metal. They wear down like brake pads. They are replaceable.
berch 69GMC is offline   Reply With Quote
Old 03-06-2017, 08:27 AM   #3
jsera
Re: door tension
Got any pics of what this should look like? I think I have the same issue
jsera is offline   Reply With Quote
Old 03-06-2017, 10:25 AM   #4
dfwright
dfwright's Avatar
Re: door tension
They are generally called Friction pads -- if you do a search on the site for "Door Friction Pads" you will find a bunch of threads with pictures and ideas for repairing them.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 03-06-2017, 11:22 AM   #5
berch 69GMC
Re: door tension
Here
Old 03-06-2017, 11:31 AM   #6
KSCHEVYUP
KSCHEVYUP's Avatar
Re: door tension
Classic Parts . com has after market replacements #(18-531) for $12.95 a pair; and I am sure some of the other vendors on the board have some also.
I am not sure what kind of a job it is to replace them?
1972 C30 Cheyenne Super
1971 C10 (Parts truck)
KSCHEVYUP is offline   Reply With Quote
Old 03-06-2017, 03:32 PM   #7
ohboy321
ohboy321's Avatar
Re: door tension
I didn't find them under that part number, but did find them under #18-432.
Here is the link: http://www.classicparts.com/1967-72-.../#.WL24nfkpX8o
I will be rebuilding mine once the weather warms up.
ohboy321 is offline   Reply With Quote
Old 03-06-2017, 03:58 PM   #8
dfwright
dfwright's Avatar
Re: door tension
It looks like that rebuild kit also comes with new roll pins, which is very good. When I pushed out my original roll pins, they were rusted up pretty bad.
