me and a buddy were sittin in his shop where he repairs diesels.we were kickin around the idea of puttin a turbo on my 350 specs in sig.it is a big truck turbo but we were thinkin about making all the piping to run the turbo.i want ur guys opinions on doing this.am i gonna grenade the motor as soon as its fired up or will it last
------------------ 72 chevy lwb 350 lunati cam ported and polished cast 2.02 heads proform hei edelbrock performer rpm and 750 carb balanced bottom end 9.5:1 compression ps,pb th350 with a tci 2500 stall convertor full man v-body kevlar clutches and bands as well as other goodies
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
A large turbo works best at high rpm, it's not going to do you that much good for the bottom end torque. 9.5:1 is too much, you should have turbo pistons in it. Stick a turbo type cam in it. Make sure the bottom end is bullit proof. Run a high volume oil pump, and a cooler. If you go with a blow thru system,you will need to pressurize the carb in a box.
------------------ 71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410 " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
being a turbo off of a diesel it would never have to run over 3500rpm thats why i figured it wouldnt be a bad idea to use it on my motor bacause it should put out at lower rpm's
A "big" Turbo is not nesesarily going to make "big" power. Your engine has to move enough air to make the turbo spin to get the boost you want.
------------------ Check out other members trucks 1968 50th Anniversary C-10 Suburban (Tows all these cars all over the place) 1968 50th Anniversary C-10 Pickup 1968 50th Anniversary C-20 Pickup CST 1969 SS Camaro Conv't 2000 Chevy Malibu (Suppose to be daily driver, but the Burb is) Phoenix, AZ. Click Here for Parts and Venicles I have Available THINGS I AM LOOKING FOR: 67-68 SUBURBAN TRIM. $$$$ Reward for finding the 3rd door trim piece and the small piece that goes on the 1/4 panel right behind the 3rd door.
Just sitting here contemplating contemplation. |
Formerly yellow72custom
Vortech makes a turbocharger for a carbed SBC. Their website would proably explain how it works...
------------------ Lucas "Another proud owner of one of the coolest trucks ever built" drop_shift@hotmail.com My Daily-Driver: '72 Chevy LWB Custom/10. Rebuilt 350, 300 HP thanks to a few go-fast goodies. Ochre with a white top. Future plans include a frame off restoration, and maybe a blown 383.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Whisky Bent & Hell Bound
It sure would be cool to see someone do this. Sure would freak out those guys with rice rockets.
------------------ 68 custom stepside 350 with Carter 650, Weiand intake, HEI, Crane Enegizer 266 cam, Headmen headers 40 series Flowmasters, B&M hole shot 2,000 rmp stall, TCI TH350 Streetfighter, 4.10 gears Virginia Beach, VA by way of Houston, TX
68 custom stepside PS,PB 350 with Vortec Heads,Carter 650, Edelbrock Performer,HEI, Crane Enegizer 266, Headmen headers 40 series Flowmasters, B&M hole shot 2,000 rmp stall, TCI TH350 Streetfighter, 4.10 gears 2003 Harley Davidson 883C San Diego, CA by way of Houston, TX |
I found an awesome site on this very subject. go to yahoo groups http://www.groups.yahoo.com and search for "blowthruturbo" and just browse thru the info on the site.You will have to have a yahoo sign-in name to join though,but no biggie. From what I've gathered there are a few different ways to turbo a carb engine. I have been thinkin on this idea for awhile,just to see a turbo'ed 350 on the street. good luck
L.E.D. Freak
Did we all forget the bad boy allready or what???
http://www.messlerproducts.com/index.htm ![]() ![]() Man if I had a million! Wow!!!!!!!!! ------------------ 1972 2wd Blazer, 350/700R4/3:73 posi/NOS. Power is nothing without control!
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
L.E.D. Freak
![]() ![]() Here's more what your after. Single turbo. Remember most of the time they recommend, a fast reving, high rpm motor and most of the time they won't do it unless, you have a SOHC conversion, to pull more RPM out of your engine safer. Also as mentioned above a oil cooler, and huge intercooler are a must. And a cool air set up and ceramic headers, heat it your main eneimy, with this type set-up, What I can't believe is they don't have a cooled air set-up on the twin turbo blazer. ------------------ 1972 2wd Blazer, 350/700R4/3:73 posi/NOS. Power is nothing without control!
Glowing since 1978
Gale Banks had a twin turbo setup out a long while ago that was making 780 HP from a race prepped 350. Sizing of a turbo or twin turbo system is very important. I believe that turbonetics had some good information on sizing for applications. This is a build from the bottom project. Forged crank is a real good idea, turbo pistons, about 7.5 to 8 compression ratio. I'm a big fan of the blow-though design. Banks used a air dump valve on the air box when the throttle was closed(hi vacuum) the valve opened this allowed the twin turbos to stay spooled up. When the throttle was punched vacuum dropped slaming the valve shut and this effectively did away with turbo lag. Turbo lag being the reason that most dislike turbos. If you work your way through all this then ensure the life blood(oil) for the turbo is always there. Moroso has an item called accusump I believe that is a gas charged reserve oil accumulator. If oil pressure drops off the accumulator discharges keeping oil on the turbo bearings to prevent failure. I'll close with this is not a slap on addition. You could probably get something from it. It would not be worth the effort unless you are willing to do it right.
------------------ 66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 79 Chevy 4X4 (Tom's old truck)
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
