Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 03-05-2017, 10:57 PM   #1
moosefd
Suburban floorboards
Hi guys need some help with rusty floorboards in my 64 burb. What manufacture have you used and how was the fit and finish. Thanks Carl
moosefd is offline   Reply With Quote
Old 03-06-2017, 12:50 AM   #2
pimpston65
pimpston65's Avatar
Re: Suburban floorboards
i got mine from lmc and had a few builders cut section for me, all had to be "worked" into place...
pimpston65 is offline   Reply With Quote
Old 03-20-2017, 11:53 PM   #3
moosefd
Pimpston what do you mean by cutting a section ? Did you have to modify the lmc floorboard if so how much?
Old 03-21-2017, 02:44 PM   #4
pimpston65
pimpston65's Avatar
i had sections from donor trucks cut into pieces i could graft in that arent repop'd. the floor pans are close but a pie pieces maybe 1/2" tapering to 3/4" round 6" long or so to make up the slack between the pan and firewall at the outer corners where they are seamed together is needed. i used 18G sheet to fab up the piece.
Old 03-21-2017, 10:09 PM   #5
moosefd
Thanks for the info
