Old 03-06-2017, 09:40 AM   #1
Brettvillo
need ideas for rear brake conversion 72 c-10
Im looking to lower my truck and thought this would be a good time to install disc brakes on the rear. any suggestions as to what kit to purchase?
Brettvillo is offline   Reply With Quote
Old 03-06-2017, 10:07 AM   #2
74baggedbug
Re: need ideas for rear brake conversion 72 c-10
Guy on the forum makes the brackets to run disc brakes..
74baggedbug is offline   Reply With Quote
Old 03-07-2017, 11:58 AM   #3
dennislbrooks
dennislbrooks's Avatar
Unless you want to see them thru fancy wheels. Leave them drums and spend the money elsewhere. Your drum emergency brake will become a parking brake with disc.
Not saying not to do it.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 03-07-2017, 12:38 PM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: need ideas for rear brake conversion 72 c-10
If I had it to do over I would have left it alone. It's not that great of a mod other than the look! If you have see through wheels. My truck is a driver and I can't tell one bit of difference in it stopping.
Does it look better, yea I guess! Is it worth $600.00 of looking better... NO.It's your truck though so do what makes you happy.
Before:
After:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
