Old 03-06-2017, 07:33 PM   #1
mild68
mild68's Avatar
need help 68 rear brake lines and hose
I'm in the process of getting the rear drum brake lines set up. Truck is a 68. The rear differential is either a 71 or 72 , 5 lug axles. The flex hose that was on the 71 72rear end connects from 1/4" steel line and has a brass T that goes to each wheel cylinder that is a 1/4" line too. I'm confused as to what the steel line size along the axle tubes should be.
The wheel cylinders take a 3/16" steel line.
The new flex line for a 68 requires a brass weather Head of sorts.
How should I set this up?
mild68 is offline   Reply With Quote
Old 03-08-2017, 03:03 PM   #2
mild68
mild68's Avatar
Re: need help 68 rear brake lines and hose
Any comments on what's up? Can I get rear wheel cylinders for 1/4" line?
Fit the lines from rear hose to 3/16"?
Old 03-08-2017, 06:32 PM   #3
68is4me
68is4me's Avatar
On my 68 c10 I ran 1/4 up to the rubber line, than 3/16 on the axle tubes. That was the sizes that were originally on it to. Can't tell you what 71-72 had
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 03-09-2017, 01:42 PM   #4
PGSigns
PGSigns's Avatar
Simple fix would be to use the line with the T on the end and put 1/4 to 3/16 reducers in it and run the 3/16 lines to the wheel cylinders.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
