Old 03-06-2017, 08:50 PM   #1
Arl37
Im stumped! Truck wont start
Went to start my 69 C10 with 350 crate engine and it wont start. Acts like I have plug wires crossed. Ran perfectly yesterday. Only work since yesterday was replacing valve cover gaskets. I have checked the plug wiring firing order 6 times and it is correct. Truck has an HEI about 6 years old. Will pull cap off tomorrow. Between now and then though I would see if anyone had any thoughts on what could be the problem.
Arl37 is offline   Reply With Quote
Old 03-06-2017, 08:54 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Im stumped! Truck wont start
Make sure all wires are seated at the cap and at the plugs
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 03-06-2017, 08:58 PM   #3
camtoys1
Make sure the distributor is not loose it have moved on you
camtoys1 is offline   Reply With Quote
Old 03-06-2017, 09:21 PM   #4
Arl37
Knocked the Bat wire loose from the HEI when I changed the valve cover gasket on the drivers side. DUH!
Old 03-06-2017, 09:27 PM   #5
hjewell2
hjewell2's Avatar
see you beat me to the punch
hjewell2 is offline   Reply With Quote
