Old 03-06-2017, 10:14 PM   #1
mehoff400
71-72 accelerator pedal
i am looking to upgrade my accelerator pedal on my truck to a cable style. i am having no luck on getting a 71-72 pedal. i have found a couple 73+ pedals. anyone know how other years fit? any suggestions on where to find a 71-72 pedal? i know lokar sells one but i am not trying to spend that much and thats not the look i am going for.
any help would be great... here is what i am trying to do get my accelerator rod to hook up to my carb.
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 03-06-2017, 11:04 PM   #2
GMDad
GMDad's Avatar
Re: 71-72 accelerator pedal
You can use your original pedal linkage very easily. This is on my 1965 Pickup with an Edelbrock carb on a 292 Inline 6 cyl motor. The bellcrank is the original one that mounted sideays on the block. I made up a plate to go across the bolts on the back of the carb and put a pivot bolt in it. Been using it for over 15 years and works great. Hope the pics give you enough detail.
GMDad is offline   Reply With Quote
Old 03-06-2017, 11:08 PM   #3
mehoff400
mmmmhhh... interesting i have access to cnc laser and could probably program something like that pretty easily.
My truck
Old 03-06-2017, 11:12 PM   #4
GMDad
GMDad's Avatar
I see you are also running a T5 trans. They work awsum behind the 6 cyl. With the cnc you could draw up something very easily and will look better than this. I like the K.I.S.S. theory and done that for years
Old 03-06-2017, 11:51 PM   #5
mehoff400
GMdad looking at your set up it wont work for what i need. i need a pull system off the carb it looks like you have a push system. i just ordered a 73+ gas pedal it looks very similar to the 71-72 pedal. plan is to use 73+ pedal along with mr gasket cable. i will update with what i make work
My truck
Old 03-07-2017, 07:33 AM   #6
GMDad
GMDad's Avatar
Mine is a pull setup. The pedal lever goes back towards the firewall. Your carb is sitting the same as mine on the intake.
