Old 03-06-2017, 11:59 PM   #1
t300
van tilt parts
Lucked out and locally picked up what I believe to be a 73(ish) van tilt. Sticker on column reads 7827343. Are the parts mostly specific to the van column or are some interchangeable with the 68-72 truck columns? Looking for the white plastic 'pointer' (does it have a cover?) as well as indicator lens for my 4L60e. It was apparently in the guys basement for 15-20 years. Feels pretty tight so I don't think I'm going to disassemble, just a fresh coat of paint.
thanks!
Matt
t300 is offline   Reply With Quote
Old 03-07-2017, 01:23 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: van tilt parts
thanks!
Matt
I am dealing on one right now, hopefully I will pick it up tomorrow. Not sure on the parts interchangeability but I hope they are. I just read a post on here the other day that said the indicator pointer was available but I don't remember what forum I was on when I read it. It is the same as the older ones. If I find the post I was reading I will post a link to it here.
Don't dissemble it unless you absolutely have to.....
LockDoc
Leon
Old 03-07-2017, 02:48 AM   #3
FirstOwner69
FirstOwner69's Avatar
Re: van tilt parts
Most things are interchangeable except the lower shaft, which is about 2-1/2" longer than a truck tilt, the levers, the rubber piece at the dash and the firewall seals. The neutral safety switch is in a different location and, I think, requires a different connector. The script on the lens is also slightly different, but it sounds like that's not a concern for you. The van column can be used in the truck with minor modifications. There are many threads on this such as this one http://67-72chevytrucks.com/vboard/s...d.php?t=133937. The pointer is the same and is available from most vendors. It is not covered. Below is a picture of the pointer installed as well as one showing the 3 tilt columns that can be used in these trucks . The middle column is a true truck tilt, the top is an RV column and the bottom is a van column.
EDIT: It appears that LMC (and probably others) sell a lens for the 700R4 trans. Would that also work with a 4L60E?
FirstOwner69 is offline   Reply With Quote
Old 03-07-2017, 09:57 AM   #4
midniteblues
midniteblues's Avatar
Re: van tilt parts
Good info for a frequently asked question.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 03-08-2017, 12:03 AM   #5
t300
Re: van tilt parts
thanks guys!
