Old 03-07-2017, 02:22 PM   #1
hunter1123
Truck won't turn off
Hey guys recently I have been having issues with my 1970k10 not shutting off whenever turn the key to the off position. It only does when the trucks been running for 10+ minutes and it only started doing a few weeks ago and I haven't done anything to the ignition or distributor. Does anyone have any ideas? Thanks
hunter1123 is offline   Reply With Quote
Old 03-07-2017, 02:44 PM   #2
biketopia
Re: Truck won't turn off
How do you get it to shut off, if you shut it off in gear if its an auto will it shut off? Could of developed a vacuum leak and its "dieseling" IE running off the heat from the exhaust valve. When it doesn't turn off, does it run smooth or kinda rougher than when the key is on?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 03-07-2017, 03:51 PM   #3
hamjet
hamjet's Avatar
bring your idle down, sounds like you're describing dieseling..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 03-07-2017, 04:22 PM   #4
cypressbog
Go Pack Go!
See how good our trucks run? They never want to shut-off
If it's not deiseling, your ignition switch may need replaced.
cypressbog is offline   Reply With Quote
Old 03-07-2017, 04:48 PM   #5
LongBox
Did these trucks ever have the "anti-dieseling" switch on the throttle linkage?
Another thought: could be deposits of carbon in the combustion chamber and on the valve heads. They get hot, then they glow, and if there's a bit too much idle throttle, they detonate the mixture and the engine keeps firing, usually really unevenly.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 03-07-2017, 05:31 PM   #6
hunter1123
It's a manual transmission and usually what I have to do it get out of the truck and undo the positive battery cable but every once in a while if I turn the lights on it will shut off when the key is off and it's still running and it runs the same whether the key is in the on or off position..it's got me pretty confused
Old 03-07-2017, 05:32 PM   #7
hunter1123
Haha I'm saying right
Old 03-07-2017, 05:40 PM   #8
geezer#99
geezer#99's Avatar
Easy to check if it's dieseling or running.
If you can drive it normally with the key off then it's not diesiling.
Old 03-07-2017, 05:47 PM   #9
hunter1123
Okay I'll give it a try
Old 03-07-2017, 08:30 PM   #10
hamjet
hamjet's Avatar
that doesn't sound like dieseling...
Thanks, Joe..
Old 03-07-2017, 08:52 PM   #11
davepl
davepl's Avatar
Short from main lug to points bypass wire at starter?
HEI plugged into wrong spot on fusebox (I know you said no changes, but something changed somewhere)?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-07-2017, 09:15 PM   #12
paul blair
Disconnect the alternator wires-start engine see if it shuts off! Maybe open diod in alternator!
paul blair is offline   Reply With Quote
Old 03-10-2017, 01:13 AM   #13
Domingo
Mine did the same thing once and it was tbe alternator back feeding power. Try removing the alternator plug and if it shuts off you need a new alternator. Just buy a 1 wire alternator cleaner anx easier
Domingo is offline   Reply With Quote
Old 03-10-2017, 02:26 AM   #14
El Dorado Jim
http://www.madelectrical.com/electri...hreewire.shtml read this before you go to a 1 wire...
El Dorado Jim is offline   Reply With Quote
Old 03-13-2017, 09:35 PM   #15
paul blair
hunter1123--Have YOU figured out why your engine wont shut off! Let us know how you are doing---might help someone else! GOOD LUCK
Old 04-26-2017, 08:49 PM   #16
paul blair
hey guys recently i have been having issues with my 1970k10 not shutting off whenever turn the key to the off position. It only does when the trucks been running for 10+ minutes and it only started doing a few weeks ago and i haven't done anything to the ignition or distributor. Does anyone have any ideas? Thanks
posted via mobile device
Have you found the problem? The fix!?
Old 04-26-2017, 09:41 PM   #17
hunter1123
Yes I have the alternator was not wired correctly since there is not an idiot light on the truck the alternator would back feed power into the ignition/distributor keeping the truck running, thankfully a $15 alternator harness with a in line diode solved he problem, thank you for following up!
Old 04-26-2017, 10:53 PM   #18
El Dorado Jim
thanks for the update
