Old 03-07-2017, 03:52 PM   #1
cottonme173
cottonme173's Avatar
Cab Bolt Hole Locations/Dimension
I am removing the cab on my 77 C20 single cab and want to make a cab stand to be able to roll it around. I am replacing a lot of rust, floor, door jams and want a stable platform to limit heat warping and the such. What I am looking for it the bolt spacing for the two front and two rear bolts and the height difference and distance between so I can make a stand that is exact to the frame (before I take the cab off and just measure my frame).
I thought this would be simple to find, but have not come across anything that is simple and to the point!
Cheers fellas and thank you!
cottonme173 is offline   Reply With Quote
Old 03-15-2017, 05:21 PM   #2
Bloodhound
Re: Cab Bolt Hole Locations/Dimension
Found this thread while looking for the same thing as you. Helped me out a bunch.
http://67-72chevytrucks.com/vboard/s...ight=cab+stand
Bloodhound is offline   Reply With Quote
