Difference in heater core?
Hi Folk's,
I searced the forum and did not see any info as to my question. I have to replace the heater core,inner and outer housing. I have a 1972 K20 with a 350. Will all the parts from a 1970 C-10 with a straight 6 work? I would think the inner and outer housings will work,but is there a difference in the heater cores? Thanks in advance for the help. Russ |
Old member
The only differences is if one is out of a AC truck. If both of them are non AC trucks your good! If both are AC trucks your good.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Difference in heater core?
Both are non-AC trucks. Thank you for the help Andy.
Old member
