Old 03-07-2017, 08:57 PM   #1
docrock
docrock's Avatar
Starting Problems
I recently bought a 1988 GMC 2500 4x4. I didn't run and was towed to my yard. I put a battery in it and turned on the key. Starter just clicked and no fuel pump sound. I changed the starter, battery cables, and fuel pump. It started and ran. When I took the tank out there was about 5 gallons of very old gas in it. Got rid of that and installed fresh gas. It didn't drive because of a clutch slave problem. I got back to working on the truck a week later, and it would not start. I thought maybe the fuel filter might be plugged. Changed it. It smelled like bad gas. Tried to start it and it wont start. Sprayed starting fluid in it and it starts and dies. I took the fuel lines off and turned the key on and it sprayed gas for a second. I am thinking that maybe injectors are plugged. I picked up some noid lights and make sure there is power getting to the injectors. I will test that tomorrow. Am I heading the wrong direction or is it something else. It does have gas about 3 gallons.
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 03-08-2017, 01:24 PM   #2
docrock
docrock's Avatar
Re: Starting Problems
no flash on the noid. so that's why it wont start.
Old 03-08-2017, 04:52 PM   #3
docrock
docrock's Avatar
when cranking with the noid installed it has a weak spark
Old 03-08-2017, 05:49 PM   #4
docrock
docrock's Avatar
Wiggled every wire and ground. used a test light to make sure grounds were good. Made sure I had at least 13 volts on the battery. Tried to start it and it stumbled. Tried it again and it started. Yahoo! Let it run until it reached operating temp, turned it off, then restarted. It works. Probably a ground or wire somewhere
