Old 03-07-2017, 11:26 PM   #1
Jason7121
Jason7121's Avatar
Paint divider cab trim mounting
Need pictures of how cab divider trim is being mounted on trucks that didn't have it originally. Are you guys using rivets or screws for the mounting clips?
Jason7121 is offline   Reply With Quote
Old 03-07-2017, 11:41 PM   #2
randy500
Re: Paint divider cab trim mounting
The dimensions and placement should be in the factory assembly manual. They use to make a special screw that replicated the stud that is welded to the cab.
They also make the exact stud for a body dent "stud gun welder" if you have access to one of those.
randy500 is offline   Reply With Quote
Old 03-07-2017, 11:58 PM   #3
Jason7121
Jason7121's Avatar
Any idea where I can get those studs we have a stud gun. Thanks for reply
Old 03-08-2017, 12:04 AM   #4
randy500
It takes a special adapter for the end of the stud gun too. What brand gun do you have. I have a box of those I think.
Old 03-08-2017, 12:05 AM   #5
randy500
Type this in google, lots of results
stud welder trim rivets
Old 03-08-2017, 12:55 AM   #6
Jason7121
Jason7121's Avatar
Thanks for info and great build btw
Old 03-08-2017, 01:06 AM   #7
Jason7121
Jason7121's Avatar
I would have to ask body shop who's helping me with it. That's nice of you I can paypal you some money for them. He has a few different guns maybe 1 would work
Old 03-08-2017, 01:15 AM   #8
randy500
Your welcome and thanks too.
If he has multiple stud guns he probably has the adapter. It looks like the adapters are available. I will have to see if I still have those, haven't used them in at least 15 years...
Old 03-08-2017, 01:20 AM   #9
Jason7121
Jason7121's Avatar
That would be great thanks
Old 03-08-2017, 10:56 AM   #10
B. W.
B. W.'s Avatar
Measured on a '72 C20
paint divider trim on back of cab: chrome trim is centered 1&5/8" above body line on back of cab
bottom of chrome trim lines up with the color split on the door, NOT the bottom of the drip rail
Measured from the edge of the door jamb, NOT the inside of the drip rail:
#1 rivet 1&1/4" from jamb
#2 rivet 5&1/4" from jamb (3&7/8" from #1)
#3 rivet centered between 10&3/4" and 10&7/8" from #2 ( 5&1/2" from #2)
#4 rivet 18&1/4" from jamb (7&1/2 from #3)
#5 rivet 9&1/2" from #4
#6 rivet 9&1/2" from #5
from forum - Chevrolet assembly instructions
measuring from the center line of the rear of cab:
2.16" down from window lip (very top with glass out?)
1st rivet 1.5" from CL
2nd rivet 9.5 from CL
3rd rivet 19" from CL
4th rivet 28.5" from CL
5th rivet (on cab corner) 0.93" foreward from rear of cab
6th rivet (one closest to door) 4.5" from rear of cab
B. W. is offline   Reply With Quote
Old 03-08-2017, 11:00 AM   #11
Jason7121
Jason7121's Avatar
Thanks for all the great information guys I appreciate all the help.
Old 03-08-2017, 01:31 PM   #12
B. W.
B. W.'s Avatar
Trim rivet stud P/N 00540 Motorguard / Magna 500 count
Electrode P/N J20009 (stud holder)
