![]() Join Date: Feb 2009
What's the deal with cutting the firewall for new fuse panels?
I'm looking at new wiring from perhaps M&H or American Auto wire.......Thing is, I saw a video on American Auto wire's "Classic" I think it's called, and them dudes had to cut the firewall.....What the?
That leaves me pondering what happens if it's a piece of junk, or someday perhaps when I'm long gone, it needs to be replaced. And there's yet another reason to cut the firewall or worse weld it up for a smaller cut. Yeah I might be paranoid. Doesn't bode well for a restoration. I saw their fuse boxes use plastic fuses as well. Bummer..Ha!.....Alright so they're more convenient, but still. Any input appreciated.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Jul 2015
Re: What's the deal with cutting the firewall for new fuse panels?
AAW has different packages. I believe they still make plug and play harness. It will be exactly like factory with all the correct plugs. I used one of there kits on my 67 camaro. All the plugs were exactly the same and fit like a glove. I think you was looking at one of there update kits which uses the newer fuses.
Just got on there web. You was on the classic series and need to be on the Factory /Oem. They also will change the hot wire for either coil or a Hei distributor for you. And also a internal or external regulated alternator. I highly recommend them. And would call and tell them what your wanting to do. It will look just like a factory harness all wrapped up. Just plug it all together.
![]() Join Date: Sep 2013
It is the same deal on Painless harnesses, the original firewall fuse block opening had to be trimmed bigger to fit the new block. The old block lasted nearly 50 years so some HFO (Happy Future Owner) can worry about fitting the next one.
I would only buy a new system made specifically for my truck, which means "Made to fit". I don't hack my truck so someone can sell me a half-assed part.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-10-2017 at 06:19 AM. |
#6 | |
#7 | |
Dennis '70 CST/10 '55 Bel Air wagon |
I'm sure I've had some AAW stuff along the way too, but I should throw out some love for M&H, since I remember being very impressed with their harness. Fit the firewall (both sides) perfectly, appeared just like stock and worked perfectly.
Go Pack Go!
I agree, M&H is also top tier for factory look and function.
Post Whore
![]() Join Date: Feb 2016
One of the reasons for having to enlarge the hole is many of the "upgrade" harnesses are much larger, having many more circuits than the stock ones did. You can only stuff some much wire in the stock cutout. Thankfully there is lots of room on our trucks and it easy to do. Try upgrading a 69 Camaro with a larger fuse box. More than the firewall has to be modified.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#11 | |
M&H offers a number of custom options - I ordered mine with HEI integrated into the harness, so it doesn't plug into IGN UNFUSED (it might behind the scenes). Not sure about TCS.
