03-08-2017, 05:41 PM | #1 |
Firewall Pad
Any experience installing?
Is it carboard with jute? How do clips hold in place? One I received looks chessy |
03-08-2017, 05:57 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Firewall Pad
They are kinda cheesy. Cardboard with jute backing. They install with plastic push in fasteners that should have come with it. I can't remember how many there are tho.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-08-2017, 05:57 PM | #3 |
Re: Firewall Pad
The clips are really ribbed plugs with a large mushroom head. They have a neat little installation tool you can buy for it, biggest thing I can tell you is when you get yours, work the factory creases a bit till it bends easier. Also grease the rib a bit (Helps push them through.
http://s1299.photobucket.com/user/jb...23904108567829 |
03-08-2017, 06:03 PM | #4 |
Re: Firewall Pad
So there should be holes in the firewall that these push clips hold onto correct
03-08-2017, 07:26 PM | #5 |
Re: Firewall Pad
Yes, the pad will come with the holes prepunched and they should line up with the holes in your firewall. Unless the PO closed them.
