03-08-2017, 10:22 PM | #1 |
Leaky air bag set up
I'm finally at the point in breathing life back into my truck that sat for 10 years where the big stuff is done. Now I need to chase the leaks in my air bag set up. I used the kids bubbles mix to spray the lines but seeing the bags is not so easy. Has anyone tried putting push connect valves in line to isolate areas to narrow the area to search? I think they are leaking out if the fittings in the bags.
03-09-2017, 12:24 AM | #2 |
Re: Leaky air bag set up
I had a bagged S10 for quite a while. It sat for the better part of 2 years while i was in Japan and then a year again while deployed to Afghanistan. It was real leaky when i got back to driving it. If i was you, id replace all the air lines. Then see what it does. I ended up rebuilding all my valves too, never had a leak again up til me selling the truck. The valves are easy to rebuild
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
03-09-2017, 11:01 PM | #3 |
Post Whore
Just my two cents worth. Adding components also adds potential leaks.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-09-2017, 11:20 PM | #4 |
I got tired of fighting my air bag leaks. installed dropped spindles and springs
03-09-2017, 11:36 PM | #5 |
I would only put the valves in to isolate the leaks then remove them. I'm going to give it a go. Then I can isolate the valves and the bags in an organized way. I'll let you know if goes.
03-10-2017, 03:14 PM | #6 |
I use 'push-in' fittings all the time in designing, building and troubleshooting industrial/automation pneumatic (air) systems.
If I want to isolate an area or a device or a line, I simply take the hose off the device and bend it back 180° and temporarily put a tie wrap on it. Despite how this sounds, it works great, it's quick, it doesn't leak and the quality of hose that I use on my projects (SMC/FESTO) suffers no degradation from this....and again, its fast. You just have to 'get good' on how to remove the hose from a push-in fitting...which requires you pushing the hose 'in', the pushing the fitting lip in...the pulling the hose back out again. Here is a quick pic of one of my typical (partial) installations My two bits. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
