front tires drag and feel binded when turning
I just replaced a bunch of parts in the front end (inner/outer tie rod, adjusting sleves, idler arm, wheel bearings) and before i did this the truck was out of alignment and now that ive replaced these parts when I turn it feels like the tires are sliding and binding like theyre fighting eachother, any help is greatly appreciated, and this is a 2wd truck not 4wd
Re: front tires drag and feel binded when turning
Did you have it realigned at a shop after installing all the new parts?
No i meant to add that to the post, i did a dirty alignment to it so i could drive it to a shop
You installed the steering cross link upside down. How do I know? We did the same thing. That long bar that connects the two sides... flip it.
71 C-20 Custom Camper California Truck |
i thought i may have done that before i installed it but when i flipped it the studs wouldnt go through the center link because the holes are tapered, unless im misunderstanding you
after looking a little bit harder at the pictures i took before taking everything out, I believe youre right, im not looking at the truck right now but im almost certain its backwards
Are the tie rods centered/ straight when the wheel is straight? I bet they are angled right now.
It sucked when we figured it it out because we had to notch the oil pan for the new placement of the bar. It will move up about 1.5" and close to the cross member by .5". (LS swap)
![]() Join Date: Jun 2009
Yes, I have seen this before.
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#11 | |
Posted via Mobile Device |
I had the same issues. My centerlink was on backwards. Had to take it all apart and turn the centerlink around. The ends of the centerlink should be angled towards the front of the truck.
72 SWB 2WD, complete frame off resto |
#13 |
Here is a pic I posted in another thread, this is how you want it.
http://67-72chevytrucks.com/vboard/s...6&postcount=14 |
Tags |
steering alignment |
