03-09-2017, 12:11 AM | #1 |
no cross member under manual transmission
I have a 1971 c10 short bed I bought about a year ago. I had the tranny taken off because of oil leaks that I wanted to take care of. Turns out the tranny has nothing supporting it other than the e-brake cables that run under it.
It is supposed to have one, correct? Would I have to custom make one or are there cross members pre made for this application? Thanks for the help. |
03-09-2017, 02:52 AM | #2 |
Re: no cross member under manual transmission
No crossmember from the factory and not needed in stock form. Chevy did that to other older model cars too.
03-09-2017, 03:08 AM | #3 |
Thanks for the reply.
I thought I had mentioned this in the first post, but does it matter if its a muncie and the case is aluminum? I've driven it about 5k miles this way with no problems that I can think of caused by. |
03-09-2017, 03:14 AM | #4 | |
I thought you were talking about the stock cast iron 3spd or 4spd, those take a lot of abuse and never seen a problem with them just hanging from the cast iron bellhousing. |
03-09-2017, 01:55 PM | #5 |
The Older Generation
The M21's don't need a rear mount either. I ran one in my '67 Short stepside for a number of years with a bell housing mount. If you are going to put a rear cross member mount in it you should remove the bell housing mount. 3 point mounting is not recommended.... LockDoc
03-26-2017, 01:53 AM | #6 |
Thanks for the replies.
