Speedometer gear
What size speedometer gear are you using?
I have a 42 tooth speedometer gear in my TH 400 trans, I'm probably reading 10 miles faster then I'm actually going, also at about 80mph the speedo needle starts to bounce badly. I don't know what size rear I have in the truck and don't want to take it apart to find out. I'm also running 22 inch transit wheels with 265/35 r22 tires that measure 29.3 in height. I think I need a smaller gear maybe a 38 tooth, any suggestions?
1963 Chevrolet C-10 |
Re: Speedometer gear
Im sorry i cant remember the business i bought mine from, but they had a calculator on their website to figure this out. It might have asked for your gear ratio, though.
There is a way to jack up your rear wheels and rotate the wheels and compare to driveshaft rotations to figure out the gear ratio, however. This would give you the number to plug into a calculator. |
Look around here for calculators.
https://transmissioncenter.net/shop/ To figure out what rear gears you have, read here. https://www.google.ca/webhp?sourceid...d+gear+ratio&* |
#4 | |
#5 | |
Your needle bouncing could be just old grease inside the cable. You might need to pull the inner cable out and clean it.
It's a brand-new speedo cable that I replaced
If you are reading fast you need a larger driven gear . Try a 44 tooth gear & check the odometer with the mile markers on the freeway.
#9 | |
I did the calculation today, I found out that I have a 3.73 rear my tire size is 29.3 so I need a 39 tooth driven gear I have a 42 tooth in there now.
Its going to read faster yet with a 39 tooth gear.
