10-17-2003, 01:49 PM | #1 |
Sisyphus was my mentor!
HELP!3-on-the-tree shifter is skrewed up!
Hey all - I pulled my truck into the garage to pull of the muffler & pulling it out the shifter broke. It's a 3-on-the-tree & it was always tight when pulling it towards you to put it into either reverse OR first. When i pulled it back this time to go into reverse, something went pop & now it's super loose, & I can feel it go into gear when i move it up or down but it just flops when you push it forward or reverse. It goes into only 2nd or third - no first or reverse. Am I screwed? How do I fix it? 3-on-the-tree shifters baffle me SO PLEASE explain the fix (if any) as easy and simplely as possible! Thank you!
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
10-17-2003, 01:56 PM | #2 |
I know there is a speing in the knuckle , right below the shift linkage, but not sure if that is what went wrong on yours. Here is where the spring is
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
10-17-2003, 02:41 PM | #3 |
CCRider
The simplest fix is to buy a floor shifter...even the cheapest offbrand parts store job will shift better than a 30 year old 3 on the tree shifter. If you spend a little more money and get a good one, you will never have another problem.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
10-17-2003, 03:09 PM | #4 |
Sounds like a linkage problem! Follow all your rods on the clutch and tranny and make sure all the clips are in, and the rods are all good. It should be fixable!
Cheers
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
10-17-2003, 05:52 PM | #5 |
Gee_Emm has another floor shift for a 3 speed for sale if you're interested. I bought one from Greg a few months back
10-17-2003, 06:06 PM | #6 |
Wiseass secured himself a BAN
Yep you need to check the shift rods and all the linkage. Sound to me that a shift rod may have slipped up. Also check that spring and the collar below that spring is tight. Make sure every thing is tight and hasn't moved.
Should be a easy fix. |
10-17-2003, 06:09 PM | #7 |
senior member
this happened to me last winter what probly happened is the shifter itself snapped. check where the shifter goes into the column and knock out that rollpin. that will answer the question of whether it was the shifter or linkage. and might I reccomend while ur doing all this take the steering wheel off and take the signal assembly out and grease the coulmn really good and geta ll the linkage greased. Mine was 30+ years old and in the winter would freeze so thats why mine broke.
69 GMC bagged |
10-17-2003, 06:30 PM | #8 |
I Love This Stuff!
I'd check that spring in the column, when mine was stuck in only first and reverse it was because the spring had broken.
My Rides 1967 C10 In Pieces for now 1985 Ford B700 SourPuss Bus - BIG BLUE 2003 Silverado CITY WORKER YELLOW!! |
10-17-2003, 10:20 PM | #9 |
ttt
10-18-2003, 01:55 AM | #10 |
senior member
what did u find out passthebuck?
69 GMC bagged |
10-18-2003, 10:40 AM | #11 |
i'm gonna try & drive out the rollpin after work tonight ( i hate workin saturdays) & I'm gonna get some oil to shoot in there & I'll keep ya updated then. Thanx all
10-18-2003, 12:24 PM | #12 |
I have 2 floorshifts and 2 3 speed columns if you need new stuff.
10-18-2003, 07:13 PM | #13 |
student wrench turner
that same thing happened to me and it was the end of the shifter that broke off. I got a new shifter handle and sprayed a whole bunch of wd-40 in there and now it works just fine.
1969 Chevy C-10 with 250 L6 2002 GMC Sierra 2500 HD Duramax with banks six gun |
10-19-2003, 05:24 PM | #14 |
update
OK_so I drove out the rollpin & YUP, the end was broken off of the shifter. I see some grease in there but its all dry SO I hosed tri-flo in there & wow it shifts great. I got a new shifter out of a 64 pontiac & the plastic end is wrong but as a fix, it's a-ok. Thank you guys for the help/tips - I dunno what I'd do without this board!
