Old 03-10-2017, 11:24 PM   #1
wHATANERD
wHATANERD's Avatar
Angry Hotchkis Upper and Lower A-Arm trouble
I have ordered and in the process of installing Hotchkis Upper and Lower A-Arms and CPP drop spindles in my 69 LWB. The trucks crossmember has been replaced with one from a 72 truck from a previous Disc Brake upgrade. The Upper A-Arms say they are designed to work with 73-87 spindles but say they will work with 71-72 if the upper ball joint is changed. I have changed the upper ball joint with the one they requested, however the upper and ball joints seem to be misaligned with each other with the lower one being about 3 inches farther forward, additionally the center axis of the spindle does not move on a level axis when moved side to side. I have added a photo of this. Any suggestion on this would be greatly appreciated.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 03-10-2017, 11:35 PM   #2
vdawg1973
Re: Hotchkis Upper and Lower A-Arm trouble
Can you please take a picture from above the upper control arm pointing down toward the ground. Just checking to make sure you don't have the two upper control arms mounted on the wrong side.
vdawg1973 is offline   Reply With Quote
Old 03-10-2017, 11:36 PM   #3
wHATANERD
wHATANERD's Avatar
I'll try to get one tomorrow
Old 03-10-2017, 11:38 PM   #4
71BUCKET
You have the uppers on the wrong side!?
71BUCKET is offline   Reply With Quote
Old 03-10-2017, 11:39 PM   #5
71BUCKET
For ref
Old 03-11-2017, 12:20 AM   #6
wHATANERD
wHATANERD's Avatar
Thanks for the ref pic
Old 03-11-2017, 09:42 AM   #7
Hart_Rod
Hart_Rod's Avatar
Are you sure you have each one on the correct side?
Hart_Rod is offline   Reply With Quote
Old 03-11-2017, 12:48 PM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
Whatanerd - I'm using the same arms, and the pic 71bucket posted is correct, you definitely have the passenger side arm installed on the drivers side. The more steeply angled portion of the arm faces the rear of the truck.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 03-11-2017, 01:57 PM   #9
wHATANERD
wHATANERD's Avatar
Smile Re: Hotchkis Upper and Lower A-Arm trouble
Thanks, the uppers were define reversed, working on correcting now.
Old 03-11-2017, 09:50 PM   #10
wHATANERD
wHATANERD's Avatar
Got the kit installed, live the trucks new stance.
Old 03-12-2017, 01:32 PM   #11
71BUCKET
Sweet. Glad you got it figured out
