![]() Join Date: Aug 2003
4wd Throttle Cable?
Is this the correct routing and bracket for a 72 four-wheel-drive with a two barrel carburetor. i've never noticed or seen this before how it winds around the back of the distributor before it goes to the carburetor.
All about them K’s
![]() Join Date: Jun 2014
Re: 4wd Throttle Cable?
No I don't think so. At least mines a 4bbl and isn't like that. I bet you've got a 2wd cable. The 4x4 cable is shorter.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
![]() Join Date: Dec 2013
are you talking throttle cable , vrs accelerator cable , one of mine has a 4 barrel but its 71 ill try and get pics in morning it does loop aroung if your talking manual throttle
I aint nobody DORK 1972 Cheyenne super k10 swb 350 4speed posi hooks 1934 ford 3 window blown 355 1969 Camaro hugger orange hounds tooth |
It's the accelerator cable. I was just curious if it was correct for two barrel carb. Didn't make sense to me why they would loop it all the way around but someone went to a lot of trouble to mount a bracket to do it.
4 wheel drive cable is shorter. My 72 C-10 has the 350 engine mounted in the rear holes of the frame (6 cyl position) And I used the 4 wd cable for my application...fits & works good.
Thanks.
