Old 03-11-2017, 06:55 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Windshield wiper motor install - Some questions for the all-knowing 67-72 board
Hopefully the captions are clear enough in these images. Just a few questions in prep to reinstall this or like unit. Thanks for any input.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-11-2017, 08:52 PM   #2
71CHEVYSHORTBED402
Re: Windshield wiper motor install - Some questions for the all-knowing 67-72 board
BTW, I just realized there's a spot in these cowls for a third transmission/wiper? It's on the RH side of the truck.
Tony
Old 03-12-2017, 01:59 AM   #3
71CHEVYSHORTBED402
Per a little research:
1. The rubber mounting pads (I called them washers) are just part of the unit. One of mine has a small crack. It would probably last another 20 years or so, though perhaps I can find something to fit.
2. The fiber element is a gasket (page 57 in assm. manual). That answers the question about the glue as well. On a side note, the assm. manual doesn't seem to show the grommet on the cowl side. It's not much of a grommet, and may be more a spacer. The hole cut into the cowl for these are large and sloppy. At least on mine it is. I'll bet a dealer or two can send me into the right direction for a gasket, and even the "grommet".
3. The rubber seal, which if I recall is very pliable (packed away at the moment). Heck I don't know, maybe there's a replacement. I don't see this in the manual either. All the book mentions is one cemented gasket. I suppose I could just clean it, though it appears to use an adhesive of some sort.
5. For lack of a better term, that's called an transmission arm bracket.
I'm replacing all elect. components on this truck, but the wiper motor and pump were great when I removed them. That said, if anyone knows of great OER replacements, may as well replace those too.
Tony
Old 03-12-2017, 08:11 AM   #4
Grumpy old man
Grumpy old man's Avatar
manestruckparts. carries all the replacement parts you mentioned as well as many other vendors .
Grumpy old man is offline   Reply With Quote
Old 03-12-2017, 08:34 AM   #5
Grumpy old man
That's for the right hand drive version of these trucks ,everything is 180 of left hand drive
Old 03-12-2017, 01:19 PM   #6
71CHEVYSHORTBED402
Thanks for the information Grumpy. Thought it might be for RH drive. The two spots on the RH side are close so it threw me off.
Edit: #5 is the crank arm. The end is a clevis pin.
Tony
