Recent Pics And Questions
hi
70 longbed 496/th400/Ford 9" |
2
3
QUESTION 1. THIS RED WIRE. WHERE SHOULD IT GO. IM GUESSING SIDE MARKER BUT I DONT KNOW. PLEASE HELP ME. MY SIDEMARKERS ARENT HOOKED UP AND IM GUESSING THATS WHERE IT SHOULD GO
THIS GREEN WIRE. WHERE DOES IT GO? IT COMES OUT OF THE FIREWALL AND GOES BEHIND THIS PLASTIC THING THEN GOES AND WRAPS AROUND A BRAKE LINE. ANY ONE KNOW?
and the wire coming off my battery is reallty shot. something is draining my battery. its to the point where i have to disconnect it when im not using it. anyone have any ideas? i have no stereo or anything that uses electricity thats aftermarket.
I see your running the same heater setup I was for awhile.
QUESTION 1. THIS RED WIRE. WHERE SHOULD IT GO. IM GUESSING SIDE MARKER BUT I DONT KNOW. PLEASE HELP ME. MY SIDEMARKERS ARENT HOOKED UP AND IM GUESSING THATS WHERE IT SHOULD GO There should be a light socket for your side markers. I think its spliced off of the parking lights. They get their power from the same source. There was not a red wire on mine for the side markers. THIS GREEN WIRE. WHERE DOES IT GO? IT COMES OUT OF THE FIREWALL AND GOES BEHIND THIS PLASTIC THING THEN GOES AND WRAPS AROUND A BRAKE LINE. ANY ONE KNOW? Im guessing temp sending unit. Mine was green. and the wire coming off my battery is reallty shot. something is draining my battery. its to the point where i have to disconnect it when im not using it. anyone have any ideas? i have no stereo or anything that uses electricity thats aftermarket You need new cables(You probably knew that). A good way to trouble shoot a battery drain is to disconect the neg batt cable and connect a test light between the cable and neg post. If the light comes on you have a drain. Start pulling fuses untill the light goes out. If it doesn't go out you wil have to dig deeper untill it does.
The more I learn about women, the more I love my truck. Last edited by 6869704X4; 10-17-2003 at 05:42 PM. |
green wire on mine is temp sender my side markers have purple wire
2004 Extended cab LS silverado ![]() 2001 Buick Lesabre 1968 Chevy Custom 10 LWB Anniversery model 2008 crew cab lt (rolling on dubs) "The nice part about living in a small town is when you don't know what you're doing, someone else always does" |
that red wire might be for the horn, mine had a red wire that ran from one horn over to the other horn
nice truck by the way
