![]() Join Date: May 2010
Installing Coil Spring pinion shims
I have a slight drive line vibration between 45-48 mph in my lowered Coil spring truck. 2.5" drop spindles with 2" lowering springs up front. The rear has 4" lowering springs. ( No C notch). Anyway my pinion angle is pointing downward. I ordered some pinion shims. They look pretty straight forward to install but I figure I would ask before i do it to save me from doing any unnecessary work.
Thanks for any advice, Matt In case anyone is need of shims this is where I ordered them from. https://www.performanceonline.com/19...ar-Suspension/
It only has original paint once |
![]() Join Date: Jan 2011
Re: Installing Coil Spring pinion shims
Pull the U-bolt and slide it in tighten the u-bolt back up. My blocks have 2 degrees milled into them.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Thanks Jimmy it sounds easy enough.
