Old 03-12-2017, 02:15 PM   #1
Cricket59
Console for aftermarket Low back buckets with car 4 speed
I've had no luck finding a console short enough in length to fit between a set of aftermarket bucket seats in my 67 C10. The whole problem is the 4 speed transmission I have is for a car and sets back further. Anyone with ideas?
Cricket59 is offline   Reply With Quote
Old 03-12-2017, 03:53 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Console for aftermarket Low back buckets with car 4 speed
http://www.cupholdersplus.com/
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 03-12-2017, 05:50 PM   #3
Cricket59
Yea I looked at those. I think the large console made for auto trans under the dash may work between the seats in my case. It's 16" long and about 12" wide. I wonder with direction would look best? Cup holders towards the front or towards the rear? I have a long straight hurst shifter with no bend approx 15" high off the floor so your arm is at a perfect 90deg bend.
Old 03-14-2017, 01:10 PM   #4
Steve Cole
Do you have a pic of the space you are working with?
Steve Cole is offline   Reply With Quote
Old 03-14-2017, 02:03 PM   #5
Lattimer
Lattimer's Avatar
I used the shorty and mounted my subwoofer under it and then used 2x4's to space it up to where I needed it. I'm running a TKO 600 trans with the engine in the rear L-6 position.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-14-2017, 02:17 PM   #6
Cricket59
Those are the exact same buckets I used but my shifter is straight and longer than that. I've looked at using that console but it didn't look like it would fit with the stock gas tank. Do you have the tank behind the seat still?
Old 03-14-2017, 02:21 PM   #7
Cricket59
Okay I'm a little slow...lol. I understand after reading your post a little better. Thanks for the pic and input. I think that's the same direction I'm going to go. By the way that interior looks awesome.
Old 03-14-2017, 02:39 PM   #8
Lattimer
Lattimer's Avatar
Thanks!!
I do still have the stock tank, and I have probably 6 inches between the carpet cover on the tank and the back of the console. I store a tool bag there. When I built it I set it up so I could rest my elbow on the console and my hand on the shifter easily and still clear the shifter all the way back. I have about 2" between the shifter and the console in 4th gear.
So with that shorty you should be able to make it fit.
Shawn
Old 03-14-2017, 02:40 PM   #9
Lattimer
Lattimer's Avatar
also, if you click the photo it takes you to my photo bucket and there are more pics of how I built it.
Shawn
Old 03-14-2017, 02:58 PM   #10
Cricket59
Thanks for all the help Shawn. I'll definitely go to the link and check it out. You've been a big help.
