Old 03-12-2017, 09:49 PM   #1
Carystone72
Vin decode isn't working on my truck.
My trucks vin is cce242b118444.
1972 Chevy 4x4 K10.
But the decoder doesen't match up with my vin. Help is appreciated thanks.
Carystone72 is offline   Reply With Quote
Old 03-12-2017, 09:56 PM   #2
Joesjunk
Joesjunk's Avatar
Re: Vin decode isn't working on my truck.
The vin tag is for a 72, 3/4 ton, 2wd.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 03-12-2017, 09:56 PM   #3
52napco
Your truck is a v8 2wd not a K10
52napco is offline   Reply With Quote
Old 03-12-2017, 10:00 PM   #4
Carystone72
Okay but it has 4x4. I have used it. It has 6 lug axles front and back, and a transfer case and locking hubs. The first two characters of my vin are CC, how could that be? It also has drum brakes front and back. I am very confused on all this haha.
Old 03-12-2017, 10:02 PM   #5
Carystone72
If you follow the vin decoder, having the first two characters be CC nakes no sense, also look at the model year (5th character) it does not match up either.
Old 03-12-2017, 10:03 PM   #6
52napco
Somebody made a 4x4 with a 2wd truck...drum brakes are 1970 and older
Old 03-12-2017, 10:10 PM   #7
Carystone72
That still does not explain the vin, the first two characters, or the character for the year, it is a 4. Which isn't listed in the decoder.
Old 03-12-2017, 10:43 PM   #8
Joesjunk
Joesjunk's Avatar
2 C's is correct for 72, no idea why they did that though. C is for 2wd, E is for V8, 2 is 3/4 ton, forgot what 4 is, 2 is for 72, B is the plant
Sounds like you have a 72 body on a 70 or older chassis. And your vin tag has the wrong rivets, so it's been removed. You should have numbers on the top frame rail near the steering box. Do you have the SPID (option sticker) on the inside of the glove box door? That gives a bunch of info
Old 03-12-2017, 10:44 PM   #9
Joesjunk
Joesjunk's Avatar
Or you could have the original body and chassis and someone swapped the vin tag?
Old 03-12-2017, 10:46 PM   #10
CG
BlahBlahBlah
C Chevy
C 2WD
E V8
2 3/4 ton
4 Pickup
2 1972
B Baltimore
The rest is the serial number
That's how I read the decoders .... http://67-72chevytrucks.com/vboard/s...d.php?t=570059
Old 03-12-2017, 10:49 PM   #11
roboticjunky
Here's a decoder for your truck.
http://www.vinwiz.com/1972-1980gmtru...=CCE242B118444
Digit Usage VIN Decoded
1 Mfgr C Chevrolet
2 Chassis C 2wd 96 inch or 106 inch conventional cab
3 Engine E V8 gas (307, 350, or 402-4v L47)
4 Series 2 3/4 ton
5 Body 4 Pickup
6 Year 2 1972
7 Plant 2 Baltimore MD
8-13 Sequential Serial # 118444 118444
roboticjunky is offline   Reply With Quote
Old 03-12-2017, 11:28 PM   #12
Carystone72
No glove box. But the frame reads 0T114217
Old 03-12-2017, 11:32 PM   #13
Carystone72
Idk if that helps but I hope it does.
Old 03-12-2017, 11:36 PM   #14
'68OrangeSunshine
'68OrangeSunshine's Avatar
So you have a frame [and maybe chassis] from a 1970 Tarrytown truck, with a swapped cab [or VIN plate] off a '72 3/4 ton Baltimore 4x2.
Is the rear-view mirror glued to the windshield? Are there little screws by your windvents? Are the door panels all plastic with molded in armrests? If all YES then it's likely a '72.
Probably ''KE140T114217" was the original truck's VIN before the chopshop got to it.
Old 03-12-2017, 11:38 PM   #15
67ChevyRedneck
67ChevyRedneck's Avatar
Yeah... that's proof positive they don't match. The last #'s on the frame should match the build sequence of the truck. If I'm reading that right, the frame is for/from a 1970 (0) T (Terrytown Plant) with a sequence # of 114217. The sequence on your VIN is 118444.
Given your location (VA) and the need for 4x4s up there and how short of a time frame before a body is bad... 4x4 frame swaps happen all the time. The body probably went to crap and they found a nicer 2wd truck with a title and used that.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-12-2017, 11:38 PM   #16
Carystone72
Where did you find this out? So I know for future refference. Also, does that mean my frame came from the factory 4x4?
Old 03-12-2017, 11:41 PM   #17
Carystone72
Thanks for all the help by the way guys.
Old 03-12-2017, 11:47 PM   #18
67ChevyRedneck
That's actually just one of those things you have to know/find out from research, but basically frames just have the plant, year, and build # on them.
It's not proof positive it's a 4x4 frame, but it is a pain in the ass to convert a 2wd frame into a 4x4 frame, so it's highly likely it's a real 4x4 frame.
Jesse James
Project "On a Dime"
Old 03-13-2017, 12:13 AM   #19
Carystone72
Also found 3975197 160 1119 12 on the frame.
Old 03-13-2017, 12:24 AM   #20
'68OrangeSunshine
Just a GM part number.
Old 03-13-2017, 12:30 AM   #21
Carystone72
Transfer case says 14008224
Old 03-13-2017, 12:30 AM   #22
'68OrangeSunshine
Most Chevy C/ series , 4x2s were built with coil springs. All Chevy and GMC K/ series trucks [4x4s] were built with leaf springs. If you have leaf springs the chassis is original, the cab [or VIN tag] was replaced. Like Redneck says, it's very unlikely anybody went to the expense and trouble to make a ''K'' out of a ''C''.
Old 03-13-2017, 12:35 AM   #23
Carystone72
I have leafs, and the shackles are riveted not bolted, and show the patina a truck from '70 would. I'm thinking it's a 4x4 frame.
Old 03-13-2017, 12:38 AM   #24
Carystone72
Tried posting a vid but it didn't work.
Old 03-13-2017, 12:40 AM   #25
'68OrangeSunshine
I don't have a reference to find that p/n.
If you're lucky, you might have an NP205 Xfer Case. Good unit. Period correct. Bombproof, geared assembly. Parts available.
If not, it could be a Rockwell T-221, Reliable, but noisy. Hard to source parts.
Or the NP203 [works on an interior drive belt] mechanically unreliable.
