Old 03-13-2017, 05:33 AM   #1
teamtwister
Alternator change
Hi looking for the right way to change to newer alternator with built in voltage regulator on a1972 chevy c10
teamtwister is offline   Reply With Quote
Old 03-13-2017, 09:14 AM   #2
dennislbrooks
dennislbrooks's Avatar
Re: Alternator change
This may help.
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 03-13-2017, 12:33 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
While the link posted above is simple and will work, IMO it is not the best way to do it simply because it does not compensate for voltage drop when the no. 2 terminal is looped over to the large output wire on the back of the alternator.
Also routing the large output wire directly to the battery positive will bypass the ammeter shunt and the ammeter will no longer work.
Have a look at this thread and decide for your self which way is best.
http://67-72chevytrucks.com/vboard/s...d.php?t=417872
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-13-2017, 07:24 PM   #4
Myoldtruck
Myoldtruck's Avatar
I installed a 1984 camaro, and used the LMC external voltage regulator eliminator plug. One year no problems. I also removed the amp guage in the cluster and installed a voltage gauge in its place.
Myoldtruck is offline   Reply With Quote
